348 Speedo Burned Internals | Page 8 | FerrariChat
Discussion in '348/355' started by Wade, Oct 25, 2015.
  1. sunxemx
    sunxemx Rookie
    Feb 20, 2017
    4
    Malta
    LeslieMirasole
    The CQ949 is definitely a PNP transistor and is used in an Alfa Romeo 33 speedo only with a different marking R030 which again doesn't mean anything as to correct known types.
  2. sunxemx
    sunxemx Rookie
    Feb 20, 2017
    4
    Malta
    LeslieMirasole
    #177 sunxemx, Mar 4, 2017
    Further to my posts above I have attached pics which show the board with the 92693 chip
    which shows that pin3 is not connected and as such cannot be equivalent to CA3140 which has the pin as an input to the op amp.
    The pics also show the boards use two transistors one with a configuration of EBC and the bigger transistor both PNP's has a configuration BCE looking from the front. The large transistor has not been identified as yet.
    The board show the pin 3 arrowed with no connection and the feedthrough arrowed also has no connection
  3. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #178 Wade, Mar 5, 2017
    Huge differences between the boards from your Alfa and the 348, so I can imagine why the CA3140 would not be an equivalent to the 92693 (for the Alfa).
    I rotated your second photo.
  4. sunxemx
    sunxemx Rookie
    Feb 20, 2017
    4
    Malta
    LeslieMirasole
    The huge difference is only the interface IC MC14024 to the pickup which is a different IC on the Alfa and is on a separate board.
    You cannot have two IC's with the same part number with different connections.
    I have swapped the CA3140 for the 92693 and it does not work ,Have you? If not try it and then you will prove it to yourself.
  5. Perlar
    Perlar Rookie
    May 16, 2017
    2
    According to the Alfa 33 speedo, what year (87,88?) can i find the 92693??
  6. Perlar
    Perlar Rookie
    May 16, 2017
    2
    Still any kits available? or atleast the 925693 & BDB02C
  7. northern lights
    Apr 28, 2011
    2
    Sweden
    Thomas Lundqvist
    I have an F40 with a speedometer problem. It uses the same IC 92693. What year of the Alfa 33 uses 92693?
    Bought a speedometer from 1986 that have another IC.
  8. cardude442
    cardude442 Karting
    Jun 5, 2019
    124
    New Hampshire, USA
    Mark
    Great thread and I’ve learned a lot from it. When I took delivery on my 94 348 Spider, the speedo wasn’t working. FoA has replaced the sender on the transmission during the major and they had fixed a break in the harness.
    My board had a barely visible cooking at the same spot many shown here (attached photo).
    I did secure a used one last year and swapped it (it works) but looking to fix this and likely keep it as a spare.
    Wade and Qavion like this.
  9. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    It was a fun adventure. Hopefully yours will be a more simpler fix.
    And too bad that ///Mike is no longer a visitor here. I have much to thank him for.
  10. c7matt
    c7matt Formula Junior
    Mar 3, 2016
    338
    Greater Detroit, MI
    Fixing mine a well, does anyone have a lead on a 92693? I have an order in from a source in China, but its been 2 weeks an the tracking number has not been picked up yet.
    As for what the 92693 does, my EE friend has figured out its comparing the input signal to the output from the odometer, thats why there are 3 wires to the odo, its a sensor to close the loop between input signal and speedometer indicated speed.
    Wade likes this.
  11. m.stojanovic
    m.stojanovic F1 Rookie
    3,315
    Serbia - Niš
    Miroljub Stojanovic
    Deliveries from China (even to me in Malaysia) have always been very slow and especially now with Covid. It may easily take 1-1.5 months.
    There is no datasheet for the Harris 92693 chip. Some suppliers claim that it is equivalent to Harris CA3140 but this chip, although in the same package, appears to have different pin arrangement. Otherwise, CA3140 is an operational amplifier (see attached datasheet).
  12. c7matt
    Mar 3, 2016
    338
    Greater Detroit, MI
    From testing the CA3140 is functionally different. My EE friend has modeled the complete board in math and I had provided him that datasheet (pretty sure it was linked earlier in this thread) and it did not fit the circuit layout of the board. I have not put it in the car yet, but all the components on my board (non surface mount) have been replaced, just like Mike did. I am highly confident that I need the chip, as all the components tested within specification after they were removed from the board.
  13. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    From a website in Turkey. Expensive? Maybe google didn't translate very well. @m.stojanovic is this the same or similar to ours?
    http://eginelektronik.com/urun/92693_5615.aspx?CatId=129
  14. m.stojanovic
    3,315
    Serbia - Niš
    Miroljub Stojanovic
    Yes, this is the correct chip. The price is in Turkish Lira but it was translated to "US $" without conversion of the amount. It is about USD 16.
    c7matt and Qavion like this.
  15. c7matt
    Mar 3, 2016
    338
    Greater Detroit, MI
    I had sent a request through some supplier bidding site in china, and a supplier found me through that. DHL tracking says my chips will be here Friday, fingers crossed...
    Previous supplier i had found had two weeks doing nothing, when I asked when they would ship the cancelled my order and refunded my money.
    Qavion likes this.
  16. Qavion
    Qavion F1 World Champ
    14,630
    Ian Riddell
    Thanks for the update, Matt.
    Would you have details for your supplier? That Turkish website looks too hard to run.
  17. c7matt
    Mar 3, 2016
    338
    Greater Detroit, MI
    It ended up being the shady chinese site linked earlier. I'll confirm once the chips arrive and are the correct chips. English is def not the preferred language. If anyone state side needs a chip, I have 10 ordered (I hope) .
    Qavion likes this.
  18. c7matt
    Mar 3, 2016
    338
    Greater Detroit, MI
    Feel accomplished, was too expensive and took time, but I am feeling victorious! I have 8 spares for sale if people want to save the time, risk and hassle. Pm me. Honestly not making profit here. $20 per chip and $5 shipping if i can help anyone the brotherhood out... Image Unavailable, Please Login
    cardude442 and Qavion like this.
  19. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    are the speedos modular in that one could purchase a used one and swap the boards over?
  20. c7matt
    Mar 3, 2016
    338
    Greater Detroit, MI
    Yes, you could. it just unplugs.
  21. cardude442
    cardude442 Karting
    Jun 5, 2019
    124
    New Hampshire, USA
    Mark
    I purchased a used speedo and was going to swap the boards to keep the original odometer and found that:
    - plugs are different internally
    - odometer gearing is different
    Not sure if the used one that I purchased was previously serviced (rebuilt), but the board layout is visually identical.
    I am looking to rebuild the original and hold onto it as a spare.
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ahh there was a 2.5 and 2.7 version and a US and non US version and a mix of those. I bet part numbers are often wrong on the used market.
  23. c7matt
    Mar 3, 2016
    338
    Greater Detroit, MI
    was it another 348 speedo? All the plugs on the boards posted on this thread have been identical to mine. My "rebuilt" board below
    Wade likes this.
  24. Jeffery Gillen
    May 11, 2022
    7
  25. Jeffery Gillen
    May 11, 2022
    7
