348 spider instrument cluster blinks with right turn signal | FerrariChat
Discussion in '348/355' started by Acguy, Jan 4, 2025.
  1. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    My gauge cluster only turns on with my right turn signal. The instrument cluster light stills dims with knob at rpm.
  2. 308 GTB
    308 GTB F1 World Champ
    11,712
    New Jersey
    Barry Wolinsky
    Qavion likes this.
  3. Qavion
    Qavion F1 World Champ
    14,209
    Ian Riddell
    Running for cover. This is a weird one.
    Seems like the sort of thing caused by a ground issue. The flasher module and the gauges share a common ground terminal, "122" in the wiring diagrams, but I can't think of a specific fault which would produce this effect.
    I don't know for sure where the grounds are. They may be behind the passenger footwell relay panel (some disassembly required). View behind the relay panel:
    Or are they the earths for the HVAC sensor system?
    Do you know where your flasher module is, Eric? It should be near the driver's knee, mounted to the wheel arch, behind the carpet. If you pull the module out of the socket, do the lights still flash or not work at all?
    I don't understand why the instrument lights only work with the the right flasher, not the left.
    Sounds like a job for SuperMiro... @m.stojanovic
  4. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I will check grounds behind relay/fuses in passenger footwell tomorrow morning.
    I don’t know where the flasher module is at.
  5. Qavion
    14,209
    Ian Riddell
    Do you have a LHD car or RHD car? Are you in the USA, Europe or elsewhere?
  6. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I am in USA, left hand drive car
  7. Qavion
    14,209
    Ian Riddell
    So the flasher module should be near your left knee.
  8. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
  9. Qavion
    14,209
    Ian Riddell
    The plug can be removed, but sometimes it can be a little sticky. Actually, I don't know if USA cars have an additional acoustic repeater (clicker module). The early F355's have an acoustic repeater.
    Are there any other similar modules in that area? How many wires does that module have? It should have 4 or 5 wires on it:
    Black x 2
    Brown
    White/black x 2
  10. Qavion
    14,209
    Ian Riddell
    #10 Qavion, Jan 5, 2025
  11. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I took a pick of the the wires going into the plug
    Five wires, some match few different colors
    I pulled the plug and both blinkers blinked at the dash and the right side gauge cluster blinked still, no change
    I then checked power at the 10a fuse and had 14v constant with the blinkers on
    The third fuse from the left top( instrument light fuse)was lit up and was blinking slightly. I installed a regular 10 fuse. The cluster was as on with headlights off. The right blinker didn’t work ( left did work) at the wheel but the indicator bulb was on in the back.
    What the Heck!!
  12. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    The lighted fuse must have caused a issue
    Now that I put a normal fuse in
    Maybe
    Now I am down to instrument lights on constantly
    My right turn signal doesn’t work at the wheel but the rear indicator is on
    Qavion likes this.
  13. Qavion
    14,209
    Ian Riddell
    As we electrical folks say... If in doubt.. go to the last modification :p
    Do you mean normal behaviour with switch operation?
    At the wheel?
    Maybe just a bulb issue.
  14. m.stojanovic
    m.stojanovic F1 Rookie
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    Perhaps you should give us more information/background:
    1. Did the car already have this issue when you bought it?
    2. If not, what work was done on the car immediately prior to occurrence of the issue?
    3. Do your Parking Lights come "on" at first turn of the lights column switch?
    4. Is your "K" relay clicking when the instrument lights are blinking with the right turn signals "on"?
    5. Does the Parking Lights indicator light at the instrument cluster come "on" at first turn of the lights column switch?
    6. Does the High Beam indicator light at the instrument cluster come "on" when you switch on the High Beams?
    Ian,
    If not already done in your revisions, you should correct your diagrams regarding relay "b" (the "K" relay). The diagram versions I have need the following corrections:
    - On all relevant diagrams, relay "b" should show pins 87 and 87b (not 87a).
    - On the "Instruments" diagrams (5, 5b and 5c), pin 87 of the relay "b" should be connected to fuse #10 (not pin "87a").
    I attach the original wiring diagram for "External Lights" for your easy reference.
    Qavion likes this.
  15. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I misread post #10
    I will check voltage at fuse with blinker off and lights on
    I will check tomorrow
  16. m.stojanovic
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    Here's the PDF file. The above JPG file was too big and it automatically inserted itself into the message body (new feature of the forum?).
    Acguy likes this.
  17. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
  18. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
  19. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I printed out electrical drawings you posted and its too blurry to read
  20. m.stojanovic
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    If you use the PDF file I posted (3.2MB), it is very clear and you can zoom it a lot. Of course, it will not be easy to read if printed on A4 paper. You should download the file and view it with Adobe Reader.
    Otherwise, I'm sure Ian will provide you with his excellent diagrams (in GIF format) which you can zoom to smallest details and which are much easier to follow than the original Ferrari diagrams because Ian has coloured the links and also included many useful comments and details.
  21. Qavion
    14,209
    Ian Riddell
    This could get complicated. I have the diagram above, but I also have a somewhat blurry copy of a USA-specific lights diagram. As far as I can see, fuse 10 is attached to 87a (or whatever the second contact is).
    https://www.dropbox.com/t/CJs94OTMvSJJiw7A
    Also, in some of my diagrams, I have the note: On some cars, this is a spare relay. Functions may have been moved to another relay.
    Doesn't make much sense.
    Anyway, I've changed them as you've recommended:
    USA lights (incomplete)
    https://www.dropbox.com/t/A5Qm06f2dIrNemf3
    USA Instruments
    https://www.dropbox.com/t/X8TXZJFwGI3Qupas
  22. m.stojanovic
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    I can see that the relay "b" icon/graphics on the blur "Instruments USA" diagram you provided is that of the K-relay, same as what all other diagrams show. The output pins of the K-relay (or any other relay having the same function) are marked as 87 and 87b.
    As to which of the two K-relay pins connects to which fuses, it does not really matter as both pins function in the same way - both are disconnected from pin 30 when the relay is "off" and both are connected to pin 30 when the relay is "on". The "special" part of the function of this relay is that, when the relay is "off" the pins 87 and 87b are separated from each other. Pins 87 and 87 on the standard 5-pin relays do not separate from each other when the relay is "off".
    Since all other diagrams that show the relay "b" show pin 87 going to fuse #10 (including the "Lights USA" diagram), I think your amendment on the "Instruments USA" diagram is in order. Please provide link to your "USA Lights" diagram when complete.
    Qavion likes this.
  23. m.stojanovic
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    Acguy likes this.
  24. Qavion
    14,209
    Ian Riddell
    Not sure what you mean. The Instrument USA link in my last post shows fuse 10 on contact 87.
  25. Acguy
    Acguy Karting
    Sep 21, 2024
    63
    Eric Christian
    I Surveyed the issue, here is what I found
    I confirmed the lighted fuse is bad. I installed a new 10a fuse and started the car.
    Left blinker on
    Front left orange light blinks
    Front side orange light off
    Dash turn signal indicator on and flashing
    Right blinker on
    Instrument cluster lights blink
    Turn signal indicator blinking at dash
    Exterior lights indicator blinking at dash(hazard lights)
    Right rear orange light indicator blinks
    Rear brake lights flashing(4 bulbs, 2 each side)
    Front all 4 orange lights blink, both side markers and bumper blinker
