348 Starter Relay Modification | Page 2 | FerrariChat
Discussion in '348/355' started by Miltonian, Jun 24, 2008.
  1. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    Btw,Great thread! I will check my wiring for voltage drop
  2. gar348
    gar348 Rookie
    Jun 20, 2009
    20
    Phoenix, AZ
    Hello Jeff- I realize that your post was from 2013 but hopefully you are still on FC. So you posted questions regarding the instructions in the WR1 kit vs. the wiring of a 348 but no one ever responded with answers. It looks like you went ahead and connected the kit per the instructions (as shown in the pictures) but you never commented on whether or not it worked. I sure as hell don't want to fry anything in my car!
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,555
    Jeff
    Since fitting the relay it's never failed to start - not even once (I would get the problem quite regularly especially in hot weather) so its definitely cured it for me :)
  4. gar348
    gar348 Rookie
    Jun 20, 2009
    20
    Phoenix, AZ
    Thanks for the reply Jeff! My problem is that it won't start when the car is hot. I live in Arizona and this time of years it's over 100 outside and over 120 in my garage. The car will always start fine when it's cold but if I drive it long enough for it to heat up (10 miles or so), then shut it off, all I get is a "click" when I turn the key but the starter doesn't engage or turn. If it's not too hot I can get it to crank over and start if I turn the ignition switch on and off several times. Eventually it will turn crank and start. But if it's good and warmed up it won't crank until it has sat and cooled off for 20 minutes or so. So, I hoping that this relay will fix that.
    OK- I'll follow your instructions and pictures and hope that it works! Looks pretty simple..
  5. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,555
    Jeff
    I would certainly give it a go as it's very inexpensive to do, easily DIYable and appears to be quite a common fault :)
  6. gar348
    gar348 Rookie
    Jun 20, 2009
    20
    Phoenix, AZ
    I installed the WR1 kit per the instructions and pictures that you posted and it works great! I took it for a 1/2 hour so run out thru the desert to a nearby town at an outside temp of around 105. On the way back I was coasting down a bit of hill leading back into my town and I therefore knew that I could do a "pop the clutch" start if I had to, so I shut off the engine.. waiting a few seconds.. and turned the key and it started!! I then tried it a couple more times and it every time it cranked over beautifully and started! I pulled into the grocery store and pulled in a parking spot (outer fringe of the lot of course).. shut it off... waited a few seconds.. turned the key and it cranked and started! I went in a grabbed a few groceries and when I came out.. it cranked and started again! This NEVER would happen prior to the installation of the solenoid. What a relief to be able to stop somewhere and have it start again when I come out! Thank you Miltonian, Jeff, and all those who posted here. This problem has been plaguing me for several years now and it was solved for $35 and 1/2 hour installation time!!
    ernie likes this.
  7. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,555
    Jeff
    Thats's a great result :)
    The only thing about driving a Ferrari is that you ever break down etc you get absolutely ZERO sympathay!!!! LOL :-(
    ernie likes this.
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    So very, very, true.
    I once had the idiotic battery bullet connector, under the air box, come lose and cause the car to stop running. This was when I first had the car and didn't know what to look for. Anyway, I was stuck on a freeway off ramp and had a few people roll down thier windows, point at me, and laugh. I though that was funny because I would have done the exact same thing. Even had a trucker blow his horn at me. Bastards! LOL!!!
    ILLA NOIZ and taz355 like this.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yup been there done that.
    My F1 pump was getting worn had to drive back home in 4 th not an easy task timing lights etc without having to stop on busy streets.
    Had to stop at gate (gated community) gate was down and car stuck in gear.
    Asked for some water (they thought it was for me im sure) poured it on the pump, put in neutral, started and drove home.
    Mweanwhile others at gate were giving me the laughs and nod
  10. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,510
    Atlanta, GA
    Steve D.
    I built my relay tonight, and should have it installed in the morning.
    Great thread!
    sjd
  11. steved033
    Apr 12, 2017
    10,510
    Atlanta, GA
    Steve D.
    This might be the single most useful mod for driven cars. It starts so easy now.
    When I buy the next one, this will be the first thing I do whether it needs it or not. Mostly, because it needs it.
    sjd
    Pangea likes this.
  12. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,167
    PR, TX, GV
    Jaime
    Very helpful still 11 years later. Thanks! :)
    steved033 likes this.
  13. pmeert
    pmeert Rookie
    Sep 13, 2015
    2
    Very helpful still 12 years later. Followed it step by step and works like a dream. Thanx!
    steved033 and ernie like this.
  14. solana_sc
    solana_sc Rookie
    29
    SC, USA
    Walt Oliver
    Still very helpful after 14 years! Works great. Thanks again!
  15. DASV8
    DASV8 Rookie
    Aug 11, 2020
    38
    Dublin, OH
    Eric C.
    Well add me to the list. Got my car end of November, drove it 3 times and put away for the winter. Woke her up, changed the oil, airbox filter, fixed the broken battery connector and failing hood struts and went to fire her up and just a click when I tried to turn engine over. First time that happened and of course I had just been all over the engine bay. Went back and verified battery, all positive and grounds on the engine and found this thread last night. Was getting 12V at the solenoid signal connector on crank and 12V at the starter +B terminal but still no start. Jumped the solenoid terminal to the starter +B and she fired right up. Relay mod ASAP for me.
  16. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    The F-car would not start today, and once again the brotherhood got me back on the road. After researching everything solenoid related I was able to slowly eliminate issues starting with the battery, terminals, those crazy power connectors, rocked the car in gear and tapped the solenoid with a hammer. Then got to this thread and realized I already had this relay installed. Finally I got to a loose connection from the relay to the ignition terminal on the started solenoid. Cleaned it, 22ed it, and re-crimped. Friday night has been saved.
    Qavion likes this.
  17. seabass23
    seabass23 Karting
    Nov 6, 2016
    158
    St Albert, Alberta
    Matt
    I'm capturing this here as an alert to anyone with a CANADIAN spec 348. I installed this relay and had issues with my daytime running lights and, most critically, my brakes!
    Miro explains the issue that I encountered here in great detail (Post 59): Brake Pump Runs before startup but won't run AFTER startup!
    This should ONLY affect Canadian-spec cars since they were modified by factory with two additional relays related to the DRLs. The two relays were added in an auxiliary holder and attached to the panel in the front trunk. If you have these relays, be informed before attempting this modification.
    Miro also provides us Canadians with a solution so that the starter relay modification can still be achieved! He recommends using a motorcycle relay instead of the cube-style automotive relay (I have not tested this yet).
  18. m.stojanovic
    m.stojanovic F1 Rookie
    3,327
    Serbia - Niš
    Miroljub Stojanovic
    Just to add: motorcycle starter relay.
  19. ClydeM
    ClydeM F1 World Champ
    12,283
    Wayne, NJ
    Clyde E. McMurdy
    Every time my 355 started giving me starting trouble, I'd rebuild it with the plunger assembly. It would frequently be heavily pitted.
    This last time was too quick and I know its not the plunger.
    So I tracked down the Bosch WR1 kit. It's not readily available anymore. I'll wire one I found & let folks now if this solves my problem.
    Thanks for the thread & pics!
    as to being stuck..yah, a couple years ago on my way to some event on Long Island I got stuck in bumper to bumper traffic and turned the car off to wait it out rather than watch the coolant temps soar.
    The traffic started to move and I couldn't even get a click out of her. I did push/roll her to the shoulder and called the state towing (can't get just anybody on some roads in NY. Gotta be authorized) and yes, a number of cars rolled down their windows, pointed, snickered, laughed and commented. To the guy in the F150 - at least mine isn't a rust bucket & doesn't rust at traffic lights! :)
  20. m.stojanovic
    3,327
    Serbia - Niš
    Miroljub Stojanovic
    Using a standard automotive cube relay as a starter relay won't work on the 355, i.e. it will cause problem with the ABS relay and may also cause the starter motor to continue running after the engine has started and the key released from START position. You can search the forum and read about this issue.
    You should use a motorcycle starter relay or a snowmobile starter relay. One example (snowmobile): https://www.ebay.com/itm/STARTER-SOLENOID-RELAY-FITS-POLARIS-SNOWMOBILE-TRAIL-RMK-2004-2009-2010/291331195789?epid=2099844650&hash=item43d4b1438d:g:pFwAAOSwnDxUlKUl&vxp=mtr or https://www.ebay.com/itm/STARTER-RELAY-SOLENOID-FOR-YAMAHA-SNOWMOBILE-SNOSCOOT-80-SV80-1988-1989-1990/261783982263?epid=858959600&hash=item3cf38a90b7:g:XwcAAOSwv0tU5VRz&vxp=mtr or https://www.ebay.com/itm/STARTER-RELAY-FITS-SKI-DOO-SNOWMOBILE-EXPEDITION-LEGEND-SKANDIC-712918880/222756801193?hash=item33dd570aa9:g:KYQAAOSwSKtaYSg4&vxp=mtr
    Examples of motorcycle or small engine starter relays:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  21. ClydeM
    12,283
    Wayne, NJ
    Clyde E. McMurdy
    Mine is a 2.7 355. I would have thought not so unlike the 348s that have been fixed.
    I'll look for the other issues you report, though. thx.
  22. ARN348
    ARN348 Rookie
    Jul 28, 2024
    1
    Thanks all- 20 years+ later, the Bosch kit still does miracles. Just installed it today on my 348 as the starter refused to engage. It took me 30min to install and test and 45min to properly organise the cables in a clean way. It works perfectly. I installed the kit directly at the starter.
    Peter, FloridaIsland348 and steved033 like this.
  23. steved033
    Apr 12, 2017
    10,510
    Atlanta, GA
    Steve D.
    Awesome!! Congrats! Welcome to reliable starts!
  24. Qavion
    Qavion F1 World Champ
    14,668
    Ian Riddell
    * on 355’s with Teves brakes. It’s fine on 355’s with Bosch brakes (apparently). All F1 cars have cube relays. The F1 system controls start via these type relays.
  25. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
    Glad it worked!
    I’ve added two start buttons that have been real useful. The one at the air box is a marine grade switch that is super easy to install into the relay system and looks factory. Image Unavailable, Please Login Image Unavailable, Please Login
    Peter likes this.
