348 throttle position sensor adjustment | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Jul 10, 2014.
  1. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Yes.
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,555
    Jeff
    I don't think you can swap the seats but when I had mine fixed the upholster swapped over the the outer covers/upholstery to even out the wear.
  3. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    I think the big question is why did your TPS need adjustment?
    Has the throttle angle changed (set screw moved or cam peened onto screw)?
    Did the shaft tab wear out the TPS button (rotating interface)?
    In regards to Idle Air Control Valves, they are always working to keep idle regardless of engine temp. i.e. air density, engine load, aircon on/off etc. They are even used to dampen rapid throttle closure. If you haven't tampered with your Idle set screw, then high RPM at idle is typically indicative of a leak somewhere downstream of the throttle.
  4. Triple Black
    Triple Black Karting
    Feb 8, 2014
    217
    Millington TN
    David S
    Make sure the electrical connections on the mass air flow sensors are working. I had a bad idle issue and I wiggled the right side engine connector and the idle came back to 1K RPM.
    Use stablant 22 from Ricambi on the connectors after cleaning to help make good connections. Worked for me!!!
  5. Full
    Full Karting
    Feb 21, 2010
    198
    Crato,Ceará - Brazil
    Alessandro
    GOOD MORNING!
    ERNIE HELLO HAPPY NEW YEAR!
    FRIEND, DID ALL PROCEDURES EXPLAINED HERE, REALLY MY PARAMETERS WERE ALL OUT OF NORMAL, BUT STILL MY IDLE OSCILLATING CONTINUES!
    WHAT YOU THINK STILL miss DO OR WHERE WOULD THE PROBLEM?
    HUG!
  6. Full
    Full Karting
    Feb 21, 2010
    198
    Alessandro
    HELLO AGAIN ERNIE !!
    FRIEND, HOW AM USING THE TRANSLATOR MANY WORDS OR TECHNICAL TERMS NOT LEAVE RIGHT!
    ON THESE PROCEDURES REPORTED HERE, YOU HAVE PHOTOS FOOTSTEPS?
    THANK YOU!
  7. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Try having the ecu's (computers) relearn the intitial start up parameters. Disconnect the battery for 1 minute, then reconnect it. With all the accessories turned off, and gearbox in neutral, start the engine and let it ilde. Do not touch anything, just let the car sit and idle for at least 15 minutes. After the car has idled for 15 minutes take it for a 30 minute drive.
    The reason the ecu's need to be reset is, they take the initial readings from the throttle position sensors and use those readings to determine what engine mapping to use. Since you changed the resistance of the throttle position sensors the ecu's are calculating the mapping based on the old tps settings.
    So.........
    Anytime you change the tps settings you will need to disconnect the battery and let the car go through the initial start up parameters.
  8. Full
    Full Karting
    Feb 21, 2010
    198
    Alessandro
    OK ERNIE!
    VERY GRATEFUL FOR YOUR TRADITIONAL CORDIAL ATTENTION!
    HUG!
  9. ga68
    ga68 Karting
    May 22, 2014
    54
    Mulhouse - FRANCE
    Gaëtan
    Hello Ernie
    A big thank you for all your research and sharing.
    I have a question about the reference "0280 122 004".
    I have a 348 from 1993 and the référence is "0280 122 001" is this normal?
    Other owner in the same case as me or an error on my car?
  10. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    It's probably the replacement tps, the upgraded newer version. Some times the manufacture discontinues making a part but has another part that fits the specs.
  11. ga68
    ga68 Karting
    May 22, 2014
    54
    Mulhouse - FRANCE
    Gaëtan
    Thank you Ernie for this answer, hoping that other possessor, can give me their references.
    This could help to identify the differences between the date of release, except for a poor repair on my 348.
    Other info, I have the screws with a yellow paint, as if they were sealed of origin.
    I discover my car from your post.
    (Google Translate)
  12. sas92
    sas92 Rookie
    Apr 10, 2019
    7
    Antoine
    Hello Ernie . great information. You don’t mention the click noise when you adjust at the rest position. do you adjust when the click is heard or go further ?
    My 348 is a Motronic 2.5. Have you ohms values for my TPS . There’s only one TPS on a 2.5.
    Thanks for the information you could give me . Maybe other people have this information about the click and ohm
  13. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    I don’t know what “click” noise you are referring to. I adjusted mine purely based on the ohm resistance I stated on the first page. I don’t have the values for the 2.5 Motronic, so I can only assume they are they same. You may want to have a look in the shop manual for a ‘89 348, with the 2.5 Motronic, to see if you can find what the resistance values are.
  14. sas92
    sas92 Rookie
    Apr 10, 2019
    7
    Antoine
    Hello thanks for answer I give on YouTube at 5.33 mn the famous klick. « DIY: BMW Throttle Position Sensor ». Does mean you are at the rest idle?
  15. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    I don’t think I have ever payed attention to listening for a click. I only based what I did on the ohm resistance reading. The only click I have listened for is that of the throttle stop on the bottom of the throttle body.
  16. sas92
    sas92 Rookie
    Apr 10, 2019
    7
    Antoine
    Here’s the Bosch information:
    "For a Bosch TPS (less common):
    o Hold the throttle plate lever closed.
    o Rotate the TPS counter-clockwise until the click is heard.
    o Continue to rotate counter-clockwise until the TPS hits the end of travel (any further and it would need to open the throttle plate) then lock in place."
    So I’m gonna go counter-clockwise and go up to 1 ohm. What do you think?
  17. sas92
    sas92 Rookie
    Apr 10, 2019
    7
    Antoine
    On the workshop manual there is no info in ohms.
    I ask this because my idle is sometimes 1500 and sometimes 1000.
    The tps test with a Multimeter indicates she’s dead.
  18. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    In that case here is what I would check:
    1) idle air control valves
    Make sure that they are clean
    2) throttle bodies
    Make sure that they are clean, opening and closing at the same time on both sides and contacting the throttle stops simultaneously (you may need to adjust the throttle linkage), that they are balanced (you’ll need a manometer) making sure that the idle air bypass screws are adjusted even.
    3) vacuum lines
    Make sure the lines are all in good condition and connected properly
    4) rest the Motronic ECUs
    The ECUs will need to relearn the warm up parameters. They take the initial reading of the throttle position sensor/s and they base the mapping if the reading/s
  19. sas92
    sas92 Rookie
    Apr 10, 2019
    7
    Antoine
    Thanks Ernie. I will keep you inform ASAP.
  20. sas92
    sas92 Rookie
    Apr 10, 2019
    7
    Antoine
    Hello Ernie. I'm coming back to you about the idle that does not come down to the decelaration. It was not the TPS but the adjustment of the intake between the two banks of cylinders.it was a very weak setting.
    ernie and Qavion like this.
  21. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Glad you got it fixed, and thanks for the update.
