348 timing belt change in 2021 | Page 2 | FerrariChat
Discussion in '348/355' started by nicolaprince, Jul 9, 2021.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    I think the 458 looks very nice, even if you don't like the F1 paddles.
  2. nicolaprince
    nicolaprince Formula Junior
    May 16, 2021
    380
    Bologna, Italy
    Nicola Principato
    Do you? Personally I think she has some nice details, like the air intakes behind the side windows that look like stretched textile, but overall I think she lacks continuity, as if each bit was designed by a different person. Just my opinion.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    I’ve own my 348 for almost 20 years, in that time frame I have done two engine out services. It has been 7 years since the last belt change (time for a new belt), but before that it was 9.5 years.
    Here is my opinion on the belts, the belts themselves are TOUGH. It’s everything else you need to worry about, especially if it has never been addressed. My last engine out I did roughly EVERYTHING you could change, short of a complete rebuild.
    timing belt
    tensioner bearing
    idler bearing
    water pump
    thermostat
    front timing chain cover bearing
    rear timing chain sprocket bearing
    oil pump chain tensioner pad
    timing chain tensioner pad
    front timing chain cover gasket
    rear engine cover o-ring
    oil pan o-ring with a viton version
    front crank seal
    rear crank seal
    cam seals
    valve cover gaskets
    cam seal housing o-rings
    rear cam gaskets
    intake cam sensor
    coolant hoses
    spark plugs
    oil
    oil filter
    air filter
    coolant
    gearbox oil
    prop shaft triple seals
    re-pinned both t55 Motronic connectors with junior power timer pins (tin plated)
    And I’m probably even forgetting a few things, but you get my point.
    So this go around it’ll probably only do the belt, unless I decide to do a full rebuild, because I already did everything else.
    3 year belt changes are WAY OVERKILL in my opinion. It’s 7yrs for my car depending on how many miles get put on it. 7 years because I already replaced practically everything that was worn out over the last 30 years. That and I am the one doing the work, so all I have to pay for is parts.
    Bertil likes this.
  4. nicolaprince
    May 16, 2021
    380
    Bologna, Italy
    Nicola Principato
    Wow, thank you very much for the feedback! In this case I think part of the wear is due to mileage too beyond aging, isn’t it? Hoe many miles did you do before replacing all these parts?
    Good that you can work on it yourself, because otherwise I think it might cost a fortune.
  5. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    All cars age.
    If the car is properly maintained/serviced unless parts become completely unobtanium, I would put forth you can keep them running until countries make it ikkegal to own gasoline powered vehicles.
    It boils down to this question IMHO - do you want to be a caregiver to an elderly patient, albeit in shape with an entire medical history, who may at times need more care than others.
    Take care and nuture that you want to keep.
    And correct, if you aren't mechanical - learn or the upkeep could make those vacays harder. The brotherhood here is always here to help and most likely one of us has had the same problem. Hell, I called Ernie a few years ago and he walked me back from a cliff.
    There's no better group!
    Sent from my SM-G965U using Tapatalk
    ernie, Bertil and nicolaprince like this.
  6. Tony Moore
    Tony Moore Rookie
    Oct 16, 2019
    19
    Surrey UK
    Tony Moore
    My understanding is that the belt places a lot of tension on only a few teeth when it’s at rest, so those cars that don’t do many turnovers risk weakening the belt, hence the intervals set by the factory. Mine was done coming up for 2 years ago and it will probably get done again next year at 3 years.
  7. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Easily solved... drive it. [emoji6]
    Interesting as I hadn't heard that..
