348 weight reduction | FerrariChat
Discussion in '348/355' started by Ajax de 1e, Feb 19, 2018.
  1. Ajax de 1e
    Ajax de 1e Formula Junior
    Feb 21, 2014
    843
    Holland
    Steef
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,269
    Rip out interior (leave seats and shifter)
    Remove carpets
    Remove sound system
    Remove valance and dash--leave instrument pod
    Remove windows and mechanism, replace with plexiglass
    Ventilate rear fender guards for more airflow through radiators
    Remove A/C
    Remove Heat
    Replace bumper shock absorbers with aluminum tubes w/ flange
    But, at this point you should have a roll cage installed.
    At which point one wants:
    Stiffer springs and shocks and the car lowered
    Which requires you to strengthen where the springs apply loads to the chassis. (Upper shock towers)
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,508
    Lake Villa IL
    There aren't any bumper shock absorbers. Unless you count the rubber spacers.
    ernie likes this.
  4. Ajax de 1e
    Feb 21, 2014
    843
    Holland
    Steef
    Clutch; flightwheel.
    Remove seats, replace them for lightweight
    Wheels
    Read something about the rear window replaced for lexan/plexiglas...
    Lightweight battery....
  5. surfwolf
    surfwolf Formula 3
    1,611
    Bethany, OR
    Michael Wolfe
    Braille AGM battery & carbon fiber airbox remove a couple of heavy boat anchors. And a Fabspeed Supersport Exhaust with 200 cell cats, drop more weight & performance is waaaaay better. These changes reduce weight without loss of any creature comforts.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    #6 ernie, Feb 19, 2018
    There are 3 very easy things that can be removed that will drop around 100/lbs out of the car, especially the early models.
    1) Dual can muffler
    2) Stock Seats
    3) Stock wheels
    Replace those with some lighter weight variants and you'll drop 100/lbs easy.
    Next places that can drop weight are the body parts. Ferrari did this for the Cometizione by using light weight carbon kevlar parts.
    4) Front and rear bumpers
    5) Front hood
    6) Front quarter panels
    7) Engine deck lid
    Then the stock glass will need to be replaced with Lexan windows. You can lose a few more pounds by replacing the stock headers and catalytic converters with custom headers and hi-flow cats. You'll get a bit more power too. The brakes could also be replaced with a race setup using floating hats. That is about as far as you can go and still have the car look "stock".
    After that it's time to start stripping out everything that is not needed to drive. Basically gutting the car.
    Ajax de 1e and f355spider like this.
  7. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    That should have read Competizione. The 10 minute post edit limit expired. Speaking of, that needs to be extended.
    vvassallo and Ajax de 1e like this.
