News
348 windows problem !
Discussion in 'Technical Q&A' started by DebbieSidera, Nov 20, 2005.
  1. DebbieSidera
    DebbieSidera Karting
    122
    California
    Debbie Sidera
    First ! sorry my english !!
    My 348 no close windows ( pilot-door )
    it glass up but, no last 3 mm !!!
    What is it problem ? motor or ajust glass in window ?
    Thank' s
    see you later
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,062
    The Brickyard
    The Bad Guy
    Well your english is good enough to get your point across.
    Anyway about your window problem. If you do a search of the archives you can find lots of information on the subject. Here are some of the threads related to your problem.
    http://ferrarichat.com/forum/showthread.php?t=70995
    http://www.ferrarichat.com/forum/showthread.php?t=46232
    http://ferrarichat.com/forum/showthread.php?t=45332
    This page has many tips related to the 348
    http://webpages.charter.net/aircover/348/1994Ferrari348Spider.html
  4. No Doubt
    No Doubt Six Time F1 World Champ
    May 21, 2005
    66,156
    Vegas+Alabama
    Mr. Sideways
    What model 348 (spider, ts, tb)? If it's the spider, there is a feature that automatically lowers your windows by 3cm (to make it easier to open/close your doors).
    If so, then you can disable that feature.
  5. ernie
    Nov 19, 2001
    22,062
    The Brickyard
    The Bad Guy
    Good point No Doubt.
  6. No Doubt
    May 21, 2005
    66,156
    Vegas+Alabama
    Mr. Sideways
    Thanks. I get one right every now and again!
  8. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,960
    Milton, Wash.
    Jeff B.
    His profile says it's a 348tb.
    Still, we need more information. 3mm is less than 1/8". Are you saying that the window goes up normally, then stops 3mm from the top? Or does it go up too slowly and simply "run out of steam" before it closes all the way? Can you grab the glass and pull it up the last 3mm?
    Like Ernie said, your English is good enough to make your point, and we would be happy to help if we can. The door windows are a common problem on 348's.
  9. DebbieSidera
    122
    California
    Debbie Sidera
    #7 DebbieSidera, Nov 22, 2005
    First thanks Miltonian, ernie and doubt !
    My model is 348 Tb year 1992
    The glass stop on 3mm from top! and I can't grab the glass and pull, is imposible !
  10. ernie
    Nov 19, 2001
    22,062
    The Brickyard
    The Bad Guy
    Is the speed of windows okay? Do they slow down as they get to the top?
    If they are slowing down as they get to the top you may want to try adjusting the window guide at the and of the door. It is the black triangle shaped piece. There are some allen screws on the side of the door. You can see the screws when the door is open. They are right by the red, open door, light. Loose the screws, roll the window up, adjust it to where you like it, then tighten the screws.
    Try that and see if it helps.
    On a side note, I like the Puma's. I have been trying to find a black suede pair with the SF sheild on the heal in my size, but they are always sold out.
  11. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    My passenger side window would not travel the last 8mm (on top rubber seal) until I rewired the door connectors. The cables were breaking up at the pins increasing the electrical resistance. Windows are much faster now as well.
  13. bob348
    bob348 Formula 3
    Apr 13, 2004
    1,547
    Liege, Belgium
    Geoffrey
    I had exactly the same problem with my TB
    Since I rewired cables...no more problems
