348tb console backlights question | FerrariChat
Discussion in '348/355' started by R&D, Feb 6, 2016.
  1. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    #1 R&D, Feb 6, 2016
    I'm doing some basic winter maintenance and today I was looking for burned out bulbs. I noticed that my "interior ceiling light" button isn't backlit at night. This little module looks difficult to disassemble without breaking any plastic so I don't want to tear into it if there's no point. Is the lower left button supposed to be backlit at night? I have a 1992 348tb, and I don't think this button is present on the targa or spider. Maybe they didn't backlight it.....
  2. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    Well because my iPhone posted the pic sideways it's actually the lower right button in the pic. When oriented correctly, it's the lower left button in the console though.
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    All four of those switches are backlit in my '91.
    If you decide to repair it I hope you'll take a lot of pics and share your experience here.
    Good luck!
  4. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    Thanks for the info Mike. I guess this means I'll be pulling it apart... It looks like the back cover is partly held on by plastic pins that were heated and then "mushroomed" out to hold it in. I hate when manufacturers do **** like that. It makes it so much harder to service...
  5. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    +1
    Mine are also backlit.
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
  7. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    Well it turns out this has been done before:
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/259891-348-center-console-lights.html
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/175667-348-console-button-led-light-fix-conversion-multi-post.html
    Interestingly in both cases you can see that plastic was marred/broken in at least one spot. It goes to show that this is tricky to do without leaving marks. I went ahead and took my switch box apart. It wasn't fun. The plastic is more on the brittle side and the clips have a lot of "grab interference" so you really have to jam and twist the screwdriver to get them out. I only cracked the plastic in one part but i did gouge up all kinds of stuff around the clip areas. In addition, they have those stupid mushroomed out black pegs. Those I had to melt with the soldering iron very carefully. Again, not fun. After all that, I did find that the bulb was burned out as expected. The problem is that the bulbs are soldered onto the PCB. This was clearly not designed for servicing ever, which is very annoying. Regardless, it annoys me even more to have a burned out bulb. I don't like LEDs, so I'm going to replace this with a stock bulb and when I reassemble I may file down the retainer clips or just take them off completely and figure out how to screw the bottom on. My switch box is already messed up because someone stripped the retaining thread for the console top and just decide to force in a screw about twice the size...Looks like my ultimate downside is about $267 if I really mess it up.
    149546 PUSHBUTTON PANEL - Ricambi America, Inc.
    Long story short I HATE PLASTIC STUFF. It's easy to break/crack/scratch and you cant really restore/paint it like with metal. Also fastening methods are usually DFA (design for assembly) style, which usually means not designed for servicing.
  8. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    #8 R&D, Feb 14, 2016
    As one of the linked threads recommended, Radio Shack part number 2721092 appears to be a correct replacement for these center console button backlights.
    https://www.radioshack.com/products/radioshack-12v-microlamps-2-pack?variant=5717331205
    Of course since Radio Shack is a horrible company, I went after work Thursday to one whose online inventory said they had these lights in stock. When I got there it turns out they didn't. I learned my lesson and called another one today to make sure they really had them. Had 3 packs of 2 so I bought the store out for a grand total of $6.57 after tax. These lights do seem to be a perfect match. I am going to have an electronics tech at work desolder/resolder them for me this week. I'll try to take pics. Before reassembly I may file down the tabs a bit to make it easier to take apart for next time one of the lights burns out.
  9. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks for the followup, R&D. Looks like I'll be following in your footsteps sooner or later. After checking the switch in my car in order to answer your original question, and finding all of the switches illuminated, I found one of the lamps burned out when I drove the car the very next day. Arrggh!
  10. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    I can't stress enough how much it sucked to get that black switch box apart for me. Be really careful. It took me over an hour with multiple small flat blade screwdrivers and I still cracked it in one spot.
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Arrgh. Not at all looking forward to that, but thanks for the warning.
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #12 Wade, Feb 15, 2016
    I've been meaning to get one of these for years and now, because of "mushroomed pins" (Mondial 8 dashboard switches had them as well), it's on order.
    Soldering Iron and Hot Knife Tip
    X-Acto Soldering Iron And Hot Knife - BLICK art materials
    Also available on Amazon:
    Amazon.com: Xacto X73780 Precision Soldering Iron and Hot Knife Tip: Home Improvement
  13. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #13 Wade, Feb 15, 2016
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,545
    Jeff
  15. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks, Jeff. Those pics are helpful. It's easier to take something apart without breaking it when you know what it looks like on the inside beforehand.
  16. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,545
    Jeff
    no worries - its quite fiddly but if someone as hamfisted as me can do it anyone can :)
  17. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    #17 R&D, Feb 15, 2016
    Well I finished the repair and the backlight works again. I decided to let one of the electrical techs at work do the desoldering/soldering since they have a fancy soldering station and desoldering wick and if I try with my $5 soldering iron and mess up I'm out $267 for a new part. It took the guy about 2 minutes to make the repair. You can't even tell anything was ever done. Before reassembly, I toggled the bench grinder to get moderate speed in the grinding wheels and ground the tips of the plastic clips down some. I then finished them off with some light sanding. I also sandpapered the 3 black pins down to a smaller diameter so they wouldn't hold the white clamshell assembly as tightly into the black plastic switch box. This will make the next bulb repair easier to do, and the remaining meat on the clips is more than enough to hold it all together.
