News
355 and a random puff of smoke
Discussion in 'Technical Q&A' started by Shuey2k, Jul 30, 2004.
  1. Shuey2k
    Shuey2k Karting
    Nov 14, 2003
    245
    Clearwater, FL
    Willi Schumacher
    Ok, here are the details, I have a 99 F355 with 11,543 miles on the clock and up to today I have never had a single issue with it. I took the car out this evening and went for a quick 10 minute drive, parked the car for an hour and then started the car as usual when I noticed a puff of smoke out of the exhaust. Concerned, I jumped out of the car and it was just a quick burst of smoke that smelled like oil and was white. Never happened prior and hasn't happened the last three times I have driven the car. Do I have a reason to be concerned or is this just a random event? My first thought was the valve guides but I thought that was resolved in 97.
  3. ChalStrad
    ChalStrad Formula 3
    Jan 22, 2004
    2,249
    Lausanne Switzerland
    Peter Mann
    Sounds like an accumulation of humidity in the xhaust system after the first drive, which is quite common. Oil would be a blueish smoke.
    Otherwise could be a valve seat that is a touch worn
    In either case nothing to worry about,
  4. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Random? Has it happened since? Worst cases: worn valve guides, blown head gasket. The former would be blue smoke and do it on hard acceleration as well; the latter would be white smoke and you'd have other symptoms: coolant in the oil; wild fluxuations in temprature being two of them. Could be a broken oil ring too. You'd have gas in the oil and likely your mileage will go to crap.
    Best case: water condensation. If it doesn't happen again I wouldn't worry about it.
    Ken
  5. Shuey2k
    Shuey2k Karting
    Nov 14, 2003
    245
    Clearwater, FL
    Willi Schumacher
    Makes sense given that it has rained non stop here in FL for the past week and I did drive the car in the rain earlier in the week. Thanks
