News
355: Best Dry Weather Tires?
Discussion in 'Technical Q&A' started by Jbuffa, Jul 7, 2004.
  1. Jbuffa
    Jbuffa Rookie
    Nov 7, 2003
    28
    Atlanta
    Joseph Buffa
    I am replacing tires on a 95 355. I wanted to go with a DOT approved Comp tire like Pirelli Corsa, but can't find the correct rear tire size 265 or 275/40. So I was wondering if anyone had BF Goodrich g-force T/A KD's on their car. It seems from what I've read that these would give the maximum dry grip. Tread wear and wet weather handling are not priorities. The sizes are 225/40 18 front and 275/40 18 rear.
  2. GTRPower
    GTRPower Karting
    Mar 24, 2004
    105
    Orlando, FL
    Nick
    I run different sizes... 255/35R18 front and 295/35R18 rear. Tire diameters are the same as stock, mounted on Speedline Challenge wheels.
    The tire I use is the Michelin Pilot Sport PS2. I've looked high and low and have not found a good R compound tire in the right sizes that have reasonable treadwear- so the PS2 is the tire for me. On my other Challenge wheels I use slicks for the track.
    Keep in mind a DOT-R compound is like any other race tire- it doesn't get good traction until it gets some heat in- which means, on the street, it virtually never gets to operating temps...
  3. richard_wallace
    richard_wallace Formula 3
    1,950
    Cincinnati, Ohio
    Richard Wallace
    Take a quick search from the above search bar - about 1 month or so ago we had a huge conversation about tire sizes and brands - seach for 355 tire and you will see it out there...
    I asked the same question for my Spider - the reason I mention the search.
    Rich
  4. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,238
    DC/LA/Paris/Haleiwa
    Mr.
    Can you use these tires on stock wheels? I've been waiting for the PS2 to come in stock size because I didn't want to screw up handling.
  5. GTRPower
    GTRPower Karting
    Mar 24, 2004
    105
    Orlando, FL
    Nick
    Challenge wheels are the same size as stock-18x8 front, 18x10 rear.
  6. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I like Yokohomas and Kuhmos.
  7. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I can't comment on sizes/availability but would add to what others have said with some data.
    On my 308 I had three track days and about 400 street miles from my Kumho Victoracers (V700) before they were done.
    I know run Yoko A032R. I am about 6 or 7 track days on the rears with 50 street miles. They are holding up well (I had to replace the fronts as they were sliced by the fender lips).
    You do need to get them heated up before they work well when they are sticky to the touch.
    I think they'd be a poor investment for the street.
    Philip
