355 coolant change procedure
Discussion in '348/355' started by WATSON, Sep 4, 2013.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. WATSON
    WATSON F1 Rookie
    4,929
    WI
    Any tricks in draining and refilling the cooling system for the 355 5.2 cars?
    I see there is a bleeder screw on the top of the water elbow above the thermostat. Does this need to bled out or do the return hoses to the burp tank handle the air discharge?
    Thanks in advance for any experiences or advice.
  2. spider348
    spider348 Formula Junior
    983
    MA
    Watson, My brief coolant change procedure:
    1. Remove underside trays to allow access to radiators and block.
    2. Open expansion tank cap.
    3. Remove plugs. Drain both radiators.
    4. Remove plugs. Drain block both sides.
    5. Install both radiator and block plugs with new “o” rings and copper washers.
    6. Pump system down with my AirLIft system. Check system holds vacuum.
    7. Fill system using the AirLift system. No air pockets or purging needed using this tool.
    8. Using my wife’s turkey baster, remove coolant from expansion tank to correct factory level.
    I use BMW’s coolant product.
  3. Dave rocks
    Dave rocks F1 World Champ
    Sponsor Owner
    Nov 23, 2012
    10,802
    Orchard Park, NY
    Dave Lelonek
    LMAO! What time is Thanksgiving Dinner? LOL
  4. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    7,521
    San Carlos, CA
    Mitchell Le
    The 355 is self bleeding so no need to remove any bleeding screw. Just run it, and continue to fill up the coolant to the right level. Check the next day and top up.
  5. AVMotorsport
    AVMotorsport Karting
    226
    SoCal
    Alex V
    #5 AVMotorsport, Sep 5, 2013
    I downloaded this document somewhere in FChat (I think) many, many years ago, and have done countless coolant changes using the steps that are outlined, with great results.
    HTH, YMMV.
  6. WATSON
    WATSON F1 Rookie
    4,929
    WI
    Awesome. Exactly what I needed and worked perfectly.
    Major brotherhood points for you!
  7. Tired of seeing this ad? Upgrade now
  8. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,228
    Georgia
    Bruce
    Perfect and spot on John...THANKS
  9. WATSON
    WATSON F1 Rookie
    4,929
    WI
    OK. I did breakdown and buy an airlift system. The reviews are very good. I have never heard of it until now.
    I already have the turkey baster :)
  10. Badabing!
    Badabing! Formula Junior
    677
    NYC
    Is it possible to use the Airlift system (or some other tool) to evacuate the system?
    In other words, suck out all the coolant so you don't have to bother with all the steps necessary to drain the coolant the traditional way?
  11. johnk...
    johnk... F1 Veteran
    5,091
    Short answer, no.
