355 Do it yourself thread | Page 2 | FerrariChat
Discussion in '348/355' started by taz355, May 4, 2013.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #27 taz355, Jan 28, 2014
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #28 taz355, Jan 29, 2014
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  5. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    #30 angelis, Feb 14, 2014
    Regreasing the 348/355 flywheel
  6. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    427
    Carolinas
    Ken
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    [DQUOTE=yelcab;143066335]I have reasons to get into the 355 ECU connector and finally sorted out the wiring colors, pin functions. This is something that I spent hours looking for and never found. and so here it is.
    Sorted by Pin Number
    Row Pin Wiring Color ECU function
    Row 1 1 White Brown O2 Sensors, Post Cat, Heater
    Row 1 2 White Green Idle Valve Pin 1
    Row 1 3 Black White Injector Cylinder 1
    Row 1 4 Yellow Red Injector Cylinder 3
    Row 1 5 Yellow Injector Cylinder 4
    Row 1 6 Black Ground, Chassis
    Row 1 7 Blue White Injector Cylinder 2
    Row 1 8 Red White Check Engine Light (CEL)
    Row 1 9 NC NC
    Row 1 10 NC NC
    Row 1 11 NC NC
    Row 1 12 NC NC
    Row 1 13 NC NC
    Row 1 14 Lite Blue Thermal TCU Bank 1
    Row 1 15 White Thermal TCU Bank 2
    Row 1 16 Blue Grey Air Tempertature Sensor Pin 1
    Row 1 17 Red Black MAF Pin 2
    Row 1 18 Green O2 sensor, Pre Cat, Bank 2, Pin A
    Row 1 19 Green O2 sensor, Pre Cat, Bank 1, Pin A
    Row 1 20 Purple Crank Position Sensor pin 2
    Row 1 21 Pink Cam Phase Sensor Pin 2
    Row 1 22 NC NC
    Row 1 23 NC NC
    Row 1 24 NC NC
    Row 1 25 NC NC
    Row 1 26 Red 12V Fused
    Row 1 27 Yellow Red Main Relay Controlling 12V to Igntion System
    Row 1 28 Black Ground, Shield
    Row 2 29 Blue White Idle Valve Pin 3
    Row 2 30 Brown O2 Sensors, Pre-Cat, Heater
    Row 2 31 White Injector Cylinder 5
    Row 2 32 Blue Black Injector Cylinder 7
    Row 2 33 Yellow Green Injector Cylinder 8
    Row 2 34 Black Ground Chassis
    Row 2 35 Green Blue Injector Cylinder 6
    Row 2 36 NC NC
    Row 2 37 NC NC
    Row 2 38 NC NC
    Row 2 39 NC NC
    Row 2 40 Yellow Knock Sensor 2, Pin 1
    Row 2 41 NC NC
    Row 2 42 Pink Black NC (unknown function on Ferrari)
    Row 2 43 NC NC
    Row 2 44 Grey White Throttle Position Pin 3
    Row 2 45 Red White MAF pin 4
    Row 2 46 Blue Black Ground Analog
    Row 2 47 NC NC
    Row 2 48 NC NC
    Row 2 49 Purple White Coil Bank 1, 1-4, Pin 3
    Row 2 50 Green Coil Bank 2, 5-8, Pin 3
    Row 2 51 Pink Black Coil Bank 1, 1-4, Pin 1
    Row 2 52 Purple Black Coil Bank 2, 5-8, Pin 1
    Row 2 53 Red Blue Throttle Position Pin 2
    Row 2 54 Green 12V Power from Relay, Pin 87B
    Row 2 55 Green Black Ground Chassis
    Row 3 56 Yellow Black Ignition Lock
    Row 3 57 Blue Green Secondary airpump Relay Pin 85
    Row 3 58 NC NC
    Row 3 59 NC NC
    Row 3 60 Blue Black Programmer Memory
    Row 3 61 Grey Green Tank Vent
    Row 3 62 Red Blue Cooling Fan Relay Pin 85
    Row 3 63 Yellow Green Fuel Pump Relay Pin 85
    Row 3 64 Yellow Blue By-Pass Valve Flap
    Row 3 65 NC NC
    Row 3 66 Green Red Slow Down Light
    Row 3 67 NC NC
    Row 3 68 Green Black Air Pump
    Row 3 69 Orange White AC Turned On
    Row 3 70 Yellow Black Knock Sensor 1, Pin 1
    Row 3 71 Black White Ground Chassis
    Row 3 72 NC NC
    Row 3 73 Purple Temperature AGK
    Row 3 74 Grey Black Water Temperature Sensor 2, Pin 1
    Row 3 75 NC NC
    Row 3 76 Purple O2 Sensor, Bank 2, Post Cat, Pin A
    Row 3 77 Purple O2 Sensor, Bank 1, Post Cat, Pin A
    Row 3 78 Purple Black Crank Position Sensor pin 1
    Row 3 79 Yellow White Speed Signal
    Row 3 80 Brown Black Diagnostic Port Input (OBD2?)
    Row 3 81 NC NC
    Row 3 82 NC NC
    Row 3 83 NC NC
    Row 3 84 NC CAN BUS Ground (not used by Ferrari)
    Row 3 85 NC CAN BUS Marelli SG KUP (not used by Ferrari)
    Row 3 86 NC CAN BUS Marelli SG KUP (not used by Ferrari)
    Row 3 87 Red Grey Diagnostic Port Output (OBD2?)
    Row 3 88 Brown Grey Diagnostic Port Control
    Sorted By ECU Function
    Row Pin No Wiring Color ECU function
    Row 3 88 Brown Grey Diagnostic Port Control (OBD2?)
    Row 1 9 NC NC
    Row 1 10 NC NC
    Row 1 11 NC NC
    Row 1 12 NC NC
    Row 1 13 NC NC
    Row 1 22 NC NC
    Row 1 23 NC NC
    Row 1 24 NC NC
    Row 1 25 NC NC
    Row 2 36 NC NC
    Row 2 37 NC NC
    Row 2 38 NC NC
    Row 2 39 NC NC
    Row 2 41 NC NC
    Row 2 43 NC NC
    Row 2 47 NC NC
    Row 2 48 NC NC
    Row 3 58 NC NC
    Row 3 59 NC NC
    Row 3 65 NC NC
    Row 3 67 NC NC
    Row 3 72 NC NC
    Row 3 75 NC NC
    Row 3 81 NC NC
    Row 3 82 NC NC
    Row 3 83 NC NC
    Sorted by Wire Colors
    Row 1 9 NC NC
    Row 1 10 NC NC
    Row 1 11 NC NC
    Row 1 12 NC NC
    Row 1 13 NC NC
    Row 1 22 NC NC
    Row 1 23 NC NC
    Row 1 24 NC NC
    Row 1 25 NC NC
    Row 2 36 NC NC
    Row 2 37 NC NC
    Row 2 38 NC NC
    Row 2 39 NC NC
    Row 2 41 NC NC
    Row 2 43 NC NC
    Row 2 47 NC NC
    Row 2 48 NC NC
    Row 3 58 NC NC
    Row 3 59 NC NC
    Row 3 65 NC NC
    Row 3 67 NC NC
    Row 3 72 NC NC
    Row 3 75 NC NC
    Row 3 81 NC NC
    Row 3 82 NC NC
    Row 3 83 NC NC
    Row 1 27 Yellow Red Main Relay Controlling 12V to Ignition System
    Row 3 79 Yellow White Speed Signal[/QUOTE]
  9. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    #34 conscom, Apr 21, 2014
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  12. ready321now
    ready321now Formula Junior
    Jan 5, 2013
    507
    New Jersey
    #37 ready321now, May 4, 2014
    Prob the easiest DIY here, but might as well post it...
    After test-driving a 1997 F 355 at a dealership, I saw the carbon-fiber sticker on the interior door-handles and liked it a lot, so I did it to mine.
    you can easily order a roll of this from the web....and use it for whatever.
  13. ready321now
    Jan 5, 2013
    507
    New Jersey
    #38 ready321now, May 5, 2014
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Credit to netman thanks
    Swapped out the lever this evening. Real easy job. Here is the process:
    1 remove four screws that hold the lever mechanism in the console
    2 disconnect the wire harness connector
    3 remove the cover plate on the bottom of the unit by expanding the compression clips. There are 8 of them
    4 you will see a hole in the center of the PCB. Remove the Phillips head screw at the base of the hole. No need to remove the 3 black screws.
    5 cut a wire hanger into 4 pieces 3 inches long.
    6 use a pick to elevate the snap clip under the aluminum facial while sliding a piece of the wire hanger underneath to prevent the clip from clamping back down. You will perform this step 4 times. Once on each side.
    7 lift the aluminum facia from the blacklastic body.
    8 turn the aluminum upside down so the reverse lever is in a upside down position
    9 notice the small flat head screw. Remove to release the lever bar from the lever
    10 be sure to account for and clear the broken tabs from the mechanism
    11 insert the new part into the mechanism and screw the lever to the lever bar
    12 insert the aluminum facia back into the black plastic body. Take care to align the parts
    13 remove the hanger wire preventing he clamps from closing
    14 replace and tighten the center screw
    15 confirm mechanical operation
    16 reinstall in your car
    17 take a moment to appreciate your work and the fact you saved 3k
    18 start the car and confirm operation by selecting reverse
    19 enjoy your car
  15. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    NO DIY AC COMPRESSOR REMOVAL AND INSTALL?
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thanks to f355bob
    Remove the small panels underneath the bumper just below each fog light. Remove the wire connector to the bulb and then remove the bulb by twisting it and it will come out of the fog light assembly. I believe you turn it counterclockwise. You do not remove the whole fog light, just the bulb. Reverse.
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thanks to Wilson
    This has happened to me twice now in 4 years. Now it did it again this AM.
    Get in car, turn key to start and the tranny light stays lit and a solid 5 second beep sounds. No gear selection possible. Can hear pump running in the back.
    The cause: Last drive I turned the car off while the wheels were still moving ever so slightly.
    The result: A confused set of sensors for the F1 system.
    The cure:
    Key out of car
    Put foot on brake and hold it.
    Turn key to accessory position and wait a moment.
    With foot still on brake, turn key off.
    With foot still on the brake, start the car.
    Viola...all better.
    I wonder how many tow jobs & dealer repair bills have transpired as a result of this over the years? It is a bit unnerving at first as visions of dollar bills dance in your head.
    A friendly public service announcement to all you 355F1 drivers
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #44 taz355, Sep 6, 2014
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #46 taz355, Sep 9, 2014
    Thanks to Jeff
    I had a similar problem with 348, the gauge was very slow to show full after filling. After tearing apart the sender, I found the float just barely floats, I mean only 0.5 mm of the whole float is above the surface. New senders are NLA, at least for the 348, and my work-around involves making a new float using something called: Nytrophyl. I have a blanking plate installed in the tank so I can use the car but the project will have to wait until winter as I am working on a Porsche Targa that clowns worked on. Here is a picture, note that one contact wire is a attached to the float like a spring. When that wire breaks, it shorts against the center contact and the sender is no longer accurate. FWIW.
    Jeff Pintler
    89 348tb, 86tr, 99 360 3-pedal, S-160 bobcat
  20. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #47 drbob101, Sep 19, 2014
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thanks to Nodoubt
    OEM low beams are 9006/H4 bulbs. Light rating: 15
    GE NightHawks "9006." Light rating: 25
    GE/Toshiba HIR 9012. Light rating: 80
    Xenon bulb/ballast kit installations. Light rating: ?? Unknown, but estimated above 80.
    OEM high beams are 9005/H3 bulbs. Light rating: 120.
    GE Nighthawk "9005." Light rating: 150.
    Toshiba HIR 9011 180
    Xenon bulb/ballast kit installations. Light rating: ?? Unknown, but estimated above 200.
    HIR bulbs are pretty much what im after. I also want to upgrade my sidelight bulbs.
  22. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
