355 Do it yourself thread | Page 3 | FerrariChat
Discussion in '348/355' started by taz355, May 4, 2013.
  1. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #51 treedee3d, Oct 8, 2014
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #55 taz355, Feb 16, 2015
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thanks to Watson
    The blink during start up indicates that the system has not built pressure. Once the pressure is hit, the blinking stops.
    The pump needs to run to build the pressure. The number of blinks to accomplish that could be as high as 12 or 13. Past that, I suspect something is not right with your pump.
    Can you hear the pump running?
    If you can't, check the two large fuses in the passenger footwell.
    Then, as mentioned, check the relay next to the F1 ECU. In fact, contact Juri on this site and switch that relay anyway. The fail state of the Ferrari one is "on" and has burned up many a pump. The fail state of Juri's is "off". Yes, the car will not run if the relay fails, but they are $30. Buy two and put one in the travel kit.
    There is a pressure switch to shut the pump off once pressure is reached. Check that the wiring is not corroded.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  10. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    My 355 F1 controler doesn't have this screw on the circuit board.
    ymmv.
  11. mosierjr
    mosierjr Karting
    Sep 29, 2009
    154
    Texas USA
    J.R.
    #74 mosierjr, Feb 6, 2016
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
