355 front of engine rattle | Page 3 | FerrariChat
Discussion in '348/355' started by ActionFigure, Nov 4, 2006.
  1. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    So the tensioner gets its oil pressure from the engine oil pressure?
  2. ProCoach
    ProCoach F1 Veteran Owner
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    Hallelujah!
    I don't think people realize that the critical dimension between the crankshaft axis and the cam sprockets "grows" so much because of thermal expansion of the block and head material. These are not "tensioners," they're "de-tensioners."
    I'm satisfied that the rattle is not the tensioner, in this case. It was my judgement call and I'm comfortable with that. I understand not only the theory, but the practice. Than you, Brian, for the explanation.
    -Peter
  3. Rifledriver
    37,290
    No, unlike the Alfa V6 travesty it's self contained.
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So then the oil is pressurized by spring pressure on a plunger?
  5. Rifledriver
    37,290
    By belt tension and engine heat causing thermal expansion.
  6. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So that explains the rattle going away after warm-up on some of these "rattling" cars.
  7. Rifledriver
    37,290
    Yes, that is why I suggested it as a possibility. Interestingly I have never experienced it on a 360 so I have to assume somewhere between 95 and 99 they were improved.
  8. Rifledriver
    37,290
    It really does do both when the need arises.
    I was just describing it for those that have not seen it because there was some confusion what it did and how. It really is a good piece of engineering just some of them had problems. Another one of those subcontractor things.
    I mentioned proper setting and being able to judge their condition because so many feel all we do is take the motor out and throw a bunch of new parts at it. There is a little more to it than that and when one is considering a DIY thing that should be known. Scary when you consider the fact that there are people that haul one of these motors out and after looking at it they still cannot tell which direction the thing turns. And the objective is to get it all back together running correctly? Good luck with that one. Hope they can figure out how to bleed the brakes when they are done. Oops, thats not always the case either.
    One of the problems with 355's is they are kind of 10lbs in a 5lb bag so everything is packaged pretty tight with heat shields everywhere. They are prone to making noises and some can be hard to find. Makes a good case for a loud exhaust.
    Good luck.
  9. ProCoach
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    Now, I made a good living off those Alfa V-6 tensioners! LOL!
    Thanks, and Merry Christmas!
    -Peter
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Thanks. I did not know anything about that operation, but it sounds like decent engineering. Good to know.
    Merry Christmas
  11. Llenroc
    Llenroc F1 Veteran Rossa Subscribed
    Jun 9, 2004
    5,579
    Colorado
    Vern
    First off I didn't realize you had such strong effections for me but, I'm more into chicks, thanks hahaha.
    My answers were directed at "action figures" question (the origininal question). Not rattling pieces of metal. I was trying to stick with the original question.
    Also I never said you wouldn't see oil leaking from the tensionor I said it was uncommon. I would still bet that the tensionor rattle is "action figures" problem.
  12. Llenroc
    Jun 9, 2004
    5,579
    Colorado
    Vern
    What is interesting about that is the part number for both is the same IIRC. regards, Vern
  13. ProCoach
    Sep 15, 2004
    5,468
    VIR Raceway
    Peter Krause
    That's right, and the manufacturing date on the tensioner assemblies is 2004! When FoA installed them!
    -Peter
  14. ferrarifixer
    ferrarifixer F1 Veteran BANNED
    Jul 22, 2003
    8,520
    Melbourne
    Phil Hughes
    360's have a rubberised mount for the hydrostatic tensioner for the LH bank only... and only one of the bolts too... it seems a cronic design fault to me... and there have been 3 up grades to the part... just to make it stronger around the rigid mount, but they STILL have the rubberised mount for the other bolt on the same component...
    Ferraris first engineering solution was to fit a fail safe peg.. so that WHEN it did break, it would only move "so far" away!! and save the engine
    but the RH bank has "normal" rigid mounted units like a 355 has both banks....
    I confess to not understanding the logic behind the rubberised one hole mount.. and when they were breaking on the 360C, I simply fitted solid ones to both banks and have never seen any problem with any of them .... some now 4 years and 10,000 TRACK km later....
    For road cars I do standard.
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So do the 355's have solid ones available??
  16. ferrarifixer
    Jul 22, 2003
    8,520
    Melbourne
    Phil Hughes
    you're missing the point... 355 have solid mounted units already, as does the RH bank on a 360.
    The hydraulics are internal.
  17. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Ther was no point to miss, the current ones are "still" hydraulic and according to some threads, they will leak. If they don't or won't leak, then fabulous I already have stockers installed. Thanks for the info!
  18. ferrarifixer
    Jul 22, 2003
    8,520
    Melbourne
    Phil Hughes
    The point you missed was that 355 ONLY have solid mounted hydrostatic tensioners... yet you asked if solid ones were available....
    don't confuse the mounting method with the tensioner operation....
    355 and 360 have the same internals to the tensioners... but 360 have a rubber mounted LH bank tensioner... but only on one of the bolt holes, not both... which, to my understanding, is bad engineering as the solid hole does not have the abilty to tolerate movement around the rubberised hole...
  19. Ricard
    Ricard Formula Junior
    Jan 23, 2004
    867
    Donington Park
    Richard C
    I went from the loudest exhaust on the planet back to stock and its amazing how many noises I hear now, loud exhaust was much less stressful for me but not my neighbours! :D
  20. pbingham
    pbingham Rookie
    Oct 16, 2005
    10
    atlanta, georgia
    Porter B. Bingham
    Guys,
    had this problem on my "96" 355 and the mechanics at the dealer in atlanta that i use determined that it was rocks in the cambelts! i know it sounds rediculous but its true. Check it out!
  21. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    How in the heck do you get rocks in the cam belt? Unless you went off track into the gravel trap, but on the road?
