Does anybody know what these two code are? ODDII code 1426, I can reset it, but the check eng. light comes back on in about 30 MIN. The code does not show up in the tech. manual. ABS code 5.4 refers to low pressure for ABS to work at speeds over 40 MPH. The system has been blead, It did not correct the problem.
My 355 did that last summer... the 1428 code. Seems like it was rear catylyst or something that showed up. I also had a mass air flow sensor problem too... it was one or the other. If you need still, I will look tonight in my book as all of the codes are in my book. I can fax a copy to you if you like? The reason it comes on in about 30 minutes, after you clear the codes with your scanner, it has to be reported 3 times by the ecu before it will turn the light on.
Red 355 The code 1426 does not show up in my shop manual. If you could let me know what that code is it would help. Thanks John
