355 on 19" and 20" wheels | Page 10 | FerrariChat
Discussion in '348/355' started by Extreme, Nov 16, 2012.
  1. ChoonHound
    ChoonHound Formula 3
    May 13, 2022
    2,221
    Saint Michaels, MD
    Lucas
    Looks are, of course, subjective. I’m responding to the comment that the tire will foul. I think it’s probably close and depends on ride height and alignment settings.
  2. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    dave360, ChoonHound and nismodrifter like this.
  3. JoeCab
    JoeCab Formula Junior Silver Subscribed
    May 27, 2014
    428
    Colorado
    Joe C
    Even that size is not a slam dunk.
    Depending on tire size, it may still rub. I had an issue with a particularly wide 295/30-19 tire on a car that was not lowered. It was a very tiny amount of rubbing, and a slightly narrower tire solved it.
    Oz-ATL and Auraraptor like this.
  4. radback
    radback Formula Junior Silver Subscribed
    Dec 14, 2020
    758
    France
    dave360 likes this.
  5. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    Are these Argumented Wheels 3-piece 355 Wheels? They look good.
  6. radback
    Dec 14, 2020
    758
    France
    No idea, it's a car from Japan that I saw on instagram.
  7. lanab
    lanab Formula Junior
    Feb 21, 2016
    510
    Stockholm, Sweden
    You think these wheels would look good? i am close ordering them.
    8.5"x20 front
    11"x20 rear
  8. PeteyP
    PeteyP Formula Junior
    May 3, 2005
    830
    NJ
    Petey
    That style wheel will look amazing but 20s will negatively effect the ride more than you would like....
    lanab likes this.
  9. NeuroBeaker
    NeuroBeaker Advising Moderator Moderator
    Oct 1, 2008
    40,012
    Huntsville, AL., USA
    Andrew
    Maybe Sweden has smoother roads than New Jersey or Alabama? They can't be any worse... :oops:
    All the best,
    Andrew.
  10. ChoonHound
    May 13, 2022
    2,221
    Saint Michaels, MD
    Lucas
  11. radback
    Dec 14, 2020
    758
    France
    20" might be a little big for a 355, but with right offset I think it could look good. Especially on a lowered car.
    Don't go "stance" style with too much offset and part of the tire not in contact with the road.
    What are those wheels?
    lanab likes this.
  12. ShineKen
    ShineKen F1 World Champ Silver Subscribed
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    I’m ok with making the car look good if the effect on performance is limited.
    lanab likes this.
  13. Ob917
    Ob917 Formula Junior Silver Subscribed
    Jun 7, 2024
    350
    Cardiff CA
    OB
    Im out, but you do you. I respect that everybody does it however they want.
    Me personally im into performance stuff for performance cars.
    bobzdar likes this.
  14. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Velgen SL5
    ET71 front and ET35 rear
  15. radback
    Dec 14, 2020
    758
    France
    Forget about it!
    Wrong ET.
    Front would be tucked inside ( "Tire is 30 mm closer to suspension components. Rim is 38 mm closer to suspension components.")
    https://www.wheel-size.com/calc/?wheel1=225-40-18X7.5ET46&wheel2=235-30-20X8.5ET71&wheel3=245-30-20X8.5ET71&wheel4=225-40-19X8ET40&fcl=30mm&scl=50mm&wcl=30mm&sr=0mm
    Rear would step out ("The tire will stick out 47 mm farther. Rim will stick out 55 mm farther").
    https://www.wheel-size.com/calc/?wheel1=265-40-18X10ET77&wheel2=275-30-20X11ET35&wheel3=225-40-19X8ET40&fcl=30mm&scl=50mm&wcl=30mm&sr=0mm
  16. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Are you sure??
    I have done measurements with a wheel fitment tool and the outer edge of the wheel will be perfectly flush with edge of car, there is some room left on the inside
    Cargraphic uses also the same offset except for the front for the same width and it looks perfect.
    https://www.cargraphic.de/ihr-fahrzeug/fuer-ferrari/f355/berlinetta-spider-gts/cargraphic-tuning-programm-fuer-ferrari-355-35l-v8/felgen-und-reifen-fuer-ferrari-355-35l-v8/cargraphic-racing-felge-19-fuer-ferrari-355-35l-v8/rrfe1985341171c/
  17. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Sorry I switched front and rear
    It is ET35 front and ET71 rear
  18. radback
    Dec 14, 2020
    758
    France
    Much better fitting this way ;)
    lanab likes this.
  19. Ob917
    Jun 7, 2024
    350
    Cardiff CA
    OB
    You will definitely need to roll your fender lips or cut them if you are anything but off road height. My offsets are not as crazy and my fenders take a major beating, even rolled with 3.5deg negative camber and stiffer suspension settings.
  20. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Yes i am a bit worried about the fronts, what ETs do you have? same width?
  21. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    dave360 likes this.
  22. radback
    Dec 14, 2020
    758
    France
    Right, front ET is a little wild.
    You should stay with 8" large front wheels with ET close to original.
    Use the link I provided to find your setting.
    It is a very accurate tool.
    In my opinion the Velgen wheels look much better than the Cargraphic ones.
    lanab likes this.
  23. Ob917
    Jun 7, 2024
    350
    Cardiff CA
    OB
    Challenge wheels plus a 11mm spacer front and rear. I think that puts my front 18x8 at +60. With a 295/40 it ruined my fenders. Ive since cut and rolled them but now im going to need to paint them. Front of the car is going for paint next week.
  24. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Yes i have 17mm spacers front and rear now with original wheels.
    The rears are flush with edge but front need 11mm to get flush with edge.
  25. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
