355 reassembly | Page 2 | FerrariChat
355 reassembly
Discussion in '348/355' started by tashier, Feb 9, 2009.
  1. tashier
    tashier Formula Junior
    Sep 8, 2008
    573
    Oregon
    Sean
    Not sure what you mean by spraying the hoses with silicone spray, I understand using that to get them to slip on easier but your saying when loading the engine spray them down?
    I could use all the pictures you can send, pics of the hoses, harnesses, wiring etc. How it's all layed out and tied up. I want to make sure I get everything routed correctly.
  2. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Ha ha ha...you are sooooooooo right...lol
  3. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    I ought to be smart Vern !!! becuase most of what I know about the CH you taught me....
  4. nunov
    nunov Rookie
    Oct 26, 2006
    42
    I did not explain correctly, but you got it. Spray the ends in order for them to slip into place. Its very hard to get back at the firewall and radiators.
    I will find some pictures to send on the routing of the gearbox lines. Also make sure the throttle wire does not bind going back in.
  5. kinnie
    kinnie Formula Junior
    Nov 21, 2003
    325
    Belgium - Aarschot
    Kinnie Van Gelder
  6. Llenroc
    Llenroc F1 Veteran
    5,580
    Colorado
    Vern
    Those pics are better than the so called real porn. Crap I must be gettin' old. Anyway thanks for the pics guys.
    And as for you Bruce quit tryin' to steal the rights to that engine stand and get busy on your car, geez man don't make me come out there and do it for you. hahaha
  7. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #33 nunov, Feb 12, 2009
    Let me know if you want a particular section
  8. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Yours looks like the 2.7 with the two crank sensors there. Probably going to be some differences in wiring. Right now I'm just looking at the valley of the block and trying to figure out where to begin. The fire sensors, harness, waterpump etc. Don't even know where to begin. I just kind of studied it tonight. I did get the oil return tubes on and the crank sensor. The oil hose running from the oil filter to the left side of the block had come apart and I had to peel away the $66 heat wrap to reconnect it. Now thinking of just getting some heat tape to rewrap it with. Lots of pictures of the top of the engine without any air cleaners on would be good. The engine where it mates to the trans as well. Alternator and AC pump.
  9. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    yes please more pictures
  10. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #36 nunov, Feb 13, 2009
    Will get more soon
  11. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Nice to see that you have the new updated hydralic tensioners....
  12. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    HELP!!!!!!!!!!!!!!!!!!!! What address do u want me to send the bus ticket too...lol
  13. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #39 nunov, Feb 13, 2009
    Remember mine is a challenge engine so lots of things are taken out. If its not needed we tend to get rid of it. It should give you a hint of where things go.
    I dont have AC but I will send you that area it should become obvious.
  14. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #40 nunov, Feb 13, 2009
  15. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Great pics, some of those should help. Keep them coming.
  16. zero
    zero Guest
    Apr 24, 2007
    776
    #42 zero, Feb 13, 2009
  17. nunov
    nunov Rookie
    Oct 26, 2006
    42
    Yes challenge thing.... its a overflow for the gearbox so you dont spray it in the engine.
  18. zero
    zero Guest
    Apr 24, 2007
    776
    Oh right, thanks:) So does that connect to were the gear box breather would normally be, or somewhere else?
  19. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    i love it.pure porno to me!!!!! keep em coming
  20. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #46 nunov, Feb 13, 2009
  21. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #47 nunov, Feb 13, 2009
  22. zero
    zero Guest
    Apr 24, 2007
    776
    #48 zero, Feb 13, 2009
    Yea that looks like the same place that the road car has it breather. So is there another breather elsewhere on the box i wonder.Thanks for taking the time to post that mate.
  23. Llenroc
    Llenroc F1 Veteran
    5,580
    Colorado
    Vern
    Bus ticket??!!!! What the Hell!!! I want first class air fare. Braaahahahaha
  24. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    #50 tashier, Feb 13, 2009
    Any need for the use of threadlocker on any of the nuts and bolts? I know it's usually case by case, I never use it on my Honda car or motorcycle but on Jetskis it is a must.
    Specifically on the oil return tubes or water manifolds etc.
    Also putting the ignition wires on and from the looks of it the cylinders are numbered
    <= 1234
    <= 5678
    Correct?
