355 reassembly | Page 3 | FerrariChat
355 reassembly
Discussion in '348/355' started by tashier, Feb 9, 2009.
  1. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #51 nunov, Feb 13, 2009
    I do not use treadlock of any of the nuts and bolts with the exception of break calipers or high speed parts such as transaxle. Someone else may tell you otherwise. I have not had any issues... dont crank down on parts as some of them are delicate. Be specially careful around the radiators.
    Yes the cylinders look right as 1 is passenger side. Here are some pictures.
  2. nunov
    nunov Rookie
    Oct 26, 2006
    42
    I just read your question about the sealer material. Its a special white sealer ( I cant remember the name) I will get it for you, very thin application, it goes a long way. Make sure you just place a almost transparent layer, otherwise it makes a huge mess and its really hard to clean up later.
    Stay tuned
  3. tashier
    tashier Formula Junior
    Sep 8, 2008
    573
    Oregon
    Sean
    Enginefxr recommended Permatex Ultra Gray so that's what I used. Very thin layer and it came out nicely. I don't think the seal between the engine/trans is crucial since it's not really holding anything.
  4. nunov
    nunov Rookie
    Oct 26, 2006
    42
    I put seal on it, but you may be right. The challenge car does have one section in the mated section that needs to be sealed... check closely...I am going from memory.
  5. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Seeings how I live in a south GA peanut field you'll be doing good to get here by bus(I think one comes by here once a month)....BTW it's a 2 mile walk from the mailbox...if I know exactly when your coming I can get the bush hog out to cut u a path...haha
  6. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Help, can anyone tell me which firing sensor goes on which side of the block? I don't see any markings on them.
  7. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    #57 tashier, Feb 14, 2009
    Nevermind, I realized after pulling up the drawing on Ricambiamerica that there is two sides of the harness and that makes it easy.
  8. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    #58 tashier, Feb 14, 2009
    I don't want to make any assumptions but do the colors of the male and female connectors match? Even if I tried that theory they won't all match. There is a gray, blue and black connector, the 3 that are circled that go to either the throttle position sensor, cam sensor or firing sensor. Anyone have any info on where these go?
  9. jetfixr
    jetfixr Formula 3
    Jun 14, 2007
    1,016
    northeast
    Gone
    #59 jetfixr, Feb 14, 2009
    What the heck does enginefxr know....You MUST use Ferrari PN-123672SUKMYA55
    He's not the sharpest tool in the shed
  10. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    #60 Llenroc, Feb 14, 2009
    You are doing a CH 355 aren't you? If so that's the wrong diagram for the 2.7 Motronic (that is the 5.2 pic) there are 2 ECUs one on each side of the engine compartment near the tail lights. It might make more sense if you look at the 2.7. There are 2 TPS 1 for each ECU and one cam sensor that feeds info to both ECUs. The pic in post 42 shows what and where the cam sensor is, ie; just to the left of the arrow, blue plug. You can 1 of the TPS in the pic also just to the left of the oil filter the little black box/black plug attached to the back side of the #5 throttle body.
  11. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    NO, this is a 355 5.2. It is a 1996. No CH.
  12. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    #62 enginefxr, Feb 14, 2009
    Ha.....I see you're cracking yourself up again!
  13. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    Lookin good! I emailed you about the shield.
  14. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    Sorry Tasher for some reason I thought you doin' a CH
  15. nunov
    nunov Rookie
    Oct 26, 2006
    42
    While you have it out take time to clean everything... Your gearbox needs some loving ;-)
  16. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    No kidding. What would you recommend as the best way to do that? Brake cleaner? I'm afraid of damaging plastics with that stuff though.
  17. nunov
    nunov Rookie
    Oct 26, 2006
    42
    Break cleaner works great but yes need to worry about rubber parts. If used make sure you blow it dry with air just to make sure fluid does not stay wet agaist rubber parts. Electric cleaner for contacts and plugs.
    Simple green works great also and hose it down with water... Make sure all holes are plugged and and use light spray to rinse off.
    good luck. and great work
  18. f-man
    f-man Formula 3
    1,383
    canada
    Jeff
    AGREED!!!
  19. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Well, did a little cleaning on the gearbox with some RC car cleaner I had left over that is safe for plastics and electronics but ran out before I was done. Looks a lot better.
    Question though, in picture number 8 in the lineup above you can see the main harness that runs to the ECU. Does it run straight off the front like shown or does it go down behind the cam belt with the alternator wiring?
  20. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    #71 enginefxr, Feb 15, 2009
  21. nunov
    nunov Rookie
    Oct 26, 2006
    42
    #72 nunov, Feb 16, 2009
    Check your Transaxle boots closely they look a little larger than they should from the picture. This is a great time to address the issue if needed. You can get boot kits. The heat from the header eats the rubber and causes it to swell at speed. You dont want it to break or leak... big mess.
    Dont want to take your focus off the engine, just add it to your list at the end.
  22. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    Great pic, that works for me.
  23. tashier
    Sep 8, 2008
    573
    Oregon
    Sean
    The boots don't look the best of shape but may have to do for now. It would be a great time to do them when the engine is out like this though. There are no holes in them.
  24. nunov
    nunov Rookie
    Oct 26, 2006
    42
    Squeeze them in your end and listen for air rushing out. You can do it with the engine in later but its much easier now. The kits are VW kits, believe it or not so they are not Ferrari prices. ;-)
    Have fun.
