355 Spider Inner CV Boot Replacement | FerrariChat
Discussion in 'Technical Q&A' started by delaney, Mar 27, 2005.
  1. delaney
    delaney Formula Junior
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    Must you replace the whole axle, or can you buy just the CV boot as you can with 308's etc? The parts book shows only a complete axle.
    Regards,
    Pete
  2. vincent355
    vincent355 F1 Veteran
    6,513
    Wine Country
    Vincent
    you can replace just the boot.
  3. Ricambi America
    Sponsor Owner
    God I feel like a sleazy salesman. I apologize to everyone if it comes off that way... I'm just trying to post some information (because I've been an Fchat leach for so long) Anyway...
    Pete -
    I just sent the kits to a fellow Fchatter in TN. It comes with boots, rings, and goop all packed in a single SKU. Are you looking for gearbox or wheel side?
    http://ricambiamerica.com/product_info.php?products_id=261138
    Wheel side is 70000868; Gearbox side is 70000867
  4. delaney
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    Both gear box sides have a 1/2" rip in them. When I have the things off, maybe I should do all 4? .. comments?
    Regards,
    Pete
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    If it ain't broke don't fix it. But if it will make you feel better have at it. It is a very, very, messy job. Make sure you have plenty of disposable rags. When you take the CV joint appart, pay close attention to how the ball bearing guide inside is positioned. That way when you reassemble it everything works how it should. The job isn't hard it is just super messy. Cleaning up all the goop is the hardest part of the whole thing.
  6. yfc
    yfc Karting
    Dec 23, 2003
    212
    Geneva / Switzerland
    Christophe
    My question may sound a bit stupid, but what is a "CV boot"?
  7. Steve Magnusson
    26,772
    CV Boot = the rubber pleated boot covering the Constant-Velocity joint on the axle assembly.
    Click on the RicambiAmerica link in Daniel's post for a diagram and picture (the highlighted item 9).
  8. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    What's the best type of grease to use when repacking the cv joints and boots? Also, how much grease should each boot be loaded with?
  9. delaney
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    I replaced the boots on my 308 a couple of times. Not difficult when you get the bolts undone. Just messy.
    Anything peculiar about boot replacement for the 355 .. or is it the same ... undo the bolts and pull them out?
    Does anyhting else have to come off the car to physically get them out?
    Regards,
    Pete
  10. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    I just used a molly CV joint grease that I got at Pep Boys. You actually don't fill the boot with the grease. You pack the CV joint with the grease. The boot is to keep the grease from going all over the place when driving. I don't remember for sure how much grease you need, but I think it was something like 126 grams, or 136, or something like that. What ever the amount was, I do remember that I used about a tube and a half on each side. If you look in the shop manual it will say how much is needed.
  11. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    As for all those towels... I think I used an entire roll of blue shop towels on a roll per axle on my 308! That was scooping most of it out that i could with rags, then soaking in my favorite solvent (gasoline) to get the rest of the old grease out.
    I elected to try to use "the good stuff" which I found in the form of Redline CV-2 grease, available from places like Racer Parts Wholesale http://racerpartswholesale.com/redline6.htm Note that not many greases specifically say they're good for CV joints. As for quantity, there's a weight in the 308 book (140gm?) that corresponded to 1/3 (?) of a tube of the CV2. It turned out to be quite a bit; it was difficult to get that much in there and some people have suspected that was for the entire axle, not just one joint, but I don't subscribe to that belief.
    I haven't heard anyone mention that there's some design weakness in the 355 gearbox end boot, so I think it falls into the category "If one side wore out, the other one is likely close!" I'd do them all while it's apart.
  12. delaney
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    Just a re-post in case it gets buried. I'd like to do these fairly soon.
    Regards,
    Pete
  13. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    Do you know if the boots are the same on 348 and 355?
    They sure look very similar...
    (A can only find boots for 355 on ricambiamerica)
    Peter
