Buy
355 Tubi or not 2b
Discussion in '348/355' started by 355f, Feb 1, 2004.
  1. 355f
    355f Formula Junior
    Nov 1, 2003
    305
    Well with all the raves about Tubi I took the plunge about a year ago on my 355.
    I never liked the stock exhaust for sure, very quiet at idle and not enough zest up top.
    The Tubi fixes these issues at a cost. That cost is cabin resonance.
    Am I alone in having this opinion of a Tubi on a 355?? its worst at 2/3 K.
    If your just out for a quick blast its bearable for to use the car for distance its not something im keen to continue with.
    Question is what does one do?? capristo?? anyone fitted this and can tell me direct comparison?? fuchs??
    Would be great to have some real comments rather than I love my tubi ones please!!
  3. 96impalaSS
    96impalaSS F1 Rookie
    Dec 8, 2003
    3,504
    Hell
    Chris
    All comes down to preference. I wouldnt mind Having that rumble at highway speeds when its low into a gear. I think its aweasome. But as for some people theyd rather it just not be like that.
  4. Diablo
    Diablo Formula Junior
    The only thing you can do is place the stock one back on and wire the bypass valve open.
    With aftermarket parts, you give a little to get what you want.
    I have been in a F50 with a full Tubi system, what a blast, but don't try and talk to the person next to you at any speed...
    Good Luck with your decision.
  5. HGParts
    HGParts Formula Junior
    Mar 15, 2003
    456
    Germany
    Heiko from HGParts
    i have the capristo on my 355 and im very very happy that i went with it. tubi is a good system also fuchs but i went with the capristo because it has the special sound no system makes the special high pitch F1 sound. maybe you dont here it so good in the files i made but in real just awesom. it was so good when i first started the car i even went without the bumper on the car just to here it fully under power.
    Heiko
    HGParts
    Sponsor of FerrariChat
    email: hgparts@arcor.de
    Webshop: http://stores.andale.com/hgparts
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    FWIW
    Although on a 3.2, my tubi was also a bit boomy - great when you are in the mood, but I use mine on trips and commute and not just for track or terrorizing myself.
    My research led me to Larini (www.larinisystems.com) which uses a different technology. The Tubis use what is called an 'acoustic box' which gives that modern screaming sound at high rpms. Larini uses a more classic free flow technology that is also free flow but with a lower tone without the boom and a bit lower volume advertised. They do a lot of Lamborghinis.
    They (David Clark) have been great to work with on the phone and the price for a complete system, including s/s header manifold was quite reasonable - less expensive than Tubi for sure. They will tailor the system to do and look basically whatever the customer tells them, and go great lengths to ensure satisfaction.
    Just my experience so far. You have more vendor options with a 355, so am sure you can find what you need.
    Good luck.
    rt
  8. MurcieMurcie
    MurcieMurcie F1 Rookie
    Jan 31, 2004
    3,002
    I had Tubi on my '98 355 and had the same problem. I had a girl on a date complain all night about the noise so on our second date we took her Camry:rolleyes::p
  9. TimF40
    TimF40 Formula 3
    Nov 3, 2003
    1,031
    Seattle/Bay Area/NYC
    Tim
    Noooo, that's just not right... :-(
  10. Ed P.
    Ed P. Formula 3
    Dec 28, 2002
    2,177
    Long Island
    No Longer
    Russ, What are you doing with your old exhaust?
  11. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Ed
    Will probably put up for sale once the Larini is installed this spring.
    best
    rt
  13. Ed P.
    Ed P. Formula 3
    Dec 28, 2002
    2,177
    Long Island
    No Longer
    Let me know.....
  14. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,459
    Michigan
    Jerry Wiersma
    Heiko,
    Where is the link to the sound files that you made? Thanks, Jerry.
  15. Noelrp
    Noelrp Formula Junior
    Aug 30, 2001
    630
    SSF
    Noel
    I thought I was alone on this. The resonance in my 348 at freeway speed (60-70mph) was very intrusive.
    I ended up selling the tubi & installed a set of tubi testpipes instead.
  16. HGParts
    Mar 15, 2003
    456
    Germany
    Heiko from HGParts
    just send me an email on the link below then i will send you the files
    Heiko
    HGParts
  17. rossofiorano355
    rossofiorano355 Karting
    Dec 22, 2003
    210
    NOLA - Bham
    Ron
    Cabin resonance is the reason I have retained the stock exhaust. Not for me, but for my passengers.
