355CH - engine cover question | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by thibaut, May 27, 2014.
  1. thibaut
    thibaut Formula Junior
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    Hi,
    My 355 has the rear wing. So the weight of the cover is somewhat higher. As the cover is held up only on one side by a single lightweight rod, the cover is twisting quite a bit
    My mechanic is concerned that the twist is pretty bad and may damage the cover.
    Beyond putting a wood rod of same size on the other side if the cover stays up during extended period, has anyone come out with a more permanent fix ?
    Thanks for your help
    Best
    T
  2. m80hot
    m80hot Formula Junior
    May 15, 2006
    299
    manchester uk
    Rich
    Mine seems fine ... I will take a photo this weekend so you can check you have the correct parts in place
    You fouls always put the standard gas struts in
  3. 308 GTB
    308 GTB F1 World Champ
    11,713
    New Jersey
    Barry Wolinsky
    #3 308 GTB, May 27, 2014
  4. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    thats different to mine ..
    mine just has one
  5. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    #5 m80hot, May 27, 2014
  6. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    sagging a bit to the left now i look at it
  7. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
  8. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    Interesting -- I don't think mine has any of these parts...is it just for rigidity improvements?
  9. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    Yes. They were part of the complete rear wing kit I posted.
  10. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    My car doesnt have these. Probably another case of lightening that went too far...
  11. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    ah now i understand .. i will check mine at the weekend .. is that one on the left hand side on my pic?
  12. X11OUD
    X11OUD Formula Junior
    Mar 22, 2008
    729
    Manchester, England
    Neil
    Rich, if you look closely in your pic, my BM is between the 2 silver cars in the back ground, it's just as I tried to call you to see if you needed help lol
    Both of the challenge cars I have pics of show 2 rods.
  13. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    ha ha .. thats so funny that i caught you on the picture
    is your car out of hibernation?
    you neeed to drive the challenge
  14. The extractor
    The extractor Karting
    Dec 9, 2004
    90
    Deerfield BeachFlorida
    Dr. Joe
    I have 1995 355 ch car. The single rod is good for me. everything is straight
  15. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    Ok ... Checked my car today ...
    So if you have a wing .. There should be two struts .. Connected on the underside of wher the wing mounts and going diagonally out to the edge of the lid
    These take the load of the wing at speed..
    I then have one support that holds the lid up
    Is ur wing a genuine part ... There were afew companies who made 'improved' versions I believe ???
  16. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    I have been told the car is 'all original' but a few parts have been deleted... Will get the car in 2 weeks so will look into it then.
  17. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    #17 308 GTB, May 31, 2014
    Yes. Although the Nolder lip at the rear of the engine cover is quite rigid, the tie rods secured to the base of the wing and the lateral cover frame elements provide the necessary bracing for the wing in function.
  18. m80hot
    May 15, 2006
    299
    manchester uk
    Rich
    Yes that's how mine is fixed
  19. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    Ok based on the picture, I ammissing the to wide struts. Not the one coming from the base of the wings but the wide ones. I guess these are standard 355 items, not challenge parts ?
  20. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    #20 wrxmike, Jun 1, 2014
  21. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    Ok thanks. We are trying to obtain a set of these from the breaker who's supplied all the missing parts for the road legalisation.
