News
355F1 Solenoid
Discussion in '348/355' started by Steve355F1, May 16, 2018.
  1. Steve355F1
    Steve355F1 F1 Veteran
    Silver Subscribed Owner
    Aug 26, 2011
    9,052
    Adelaide, South Aust
    Steve
    Hi All
    Re my well documented issues (on other threads) with an intermittent failure to select gears on my car, we have managed to work out that a solenoid has failed on the F1 pump.
    (EV1 on the attached pic)
    Rather than replacing the pump, we are looking to just replace the solenoid.
    Does anyone know where I could get one, or does anyone have one lying around they’d be willing to sell to me?
    Thanks for any help.
  2. Steve355F1
    Aug 26, 2011
    9,052
    Steve
  3. Qavion
    Qavion F1 Rookie
    Feb 20, 2015
    3,132
    Ian Riddell
    Are the diagnostics saying the valve electrical circuit is open? Is it possible to dismantle these things? Any manufacturer's names? Magneti Marelli? Hydraulik-Ring? Would you have a clearer shot of the numbers on it?
    Is it a plunger type... or rotary valve?
  4. Steve355F1
    Aug 26, 2011
    9,052
    Steve
    Not sure about any of those questions sorry Ian.
    I’ve got this running in the Oz section at the moment too with what the dealer seems to have found re part no.
    It’s in the spotters thread.
    Cheers!
  5. SeattleM5
    SeattleM5 Formula Junior
    928
    Kirkland, Washington
    Ettore Palazzo
    Qavion and WATSON like this.
  6. Steve355F1
    Aug 26, 2011
    9,052
    Steve
  7. Dave rocks
    Dave rocks F1 World Champ
    15,969
    Orchard Park, NY
    Dave Lelonek
  8. SeattleM5
    928
    Ettore Palazzo
    I was pretty surprised when I came across that website a few months back. Seems they have solenoids and accumulator bulbs but they don't have the correct 355 F1 pump motor. They do advertise a pump motor which looks similar to ours but the shaft and electrical connector would need modification.
    Sent from my SM-G900V using FerrariChat.com mobile app
  9. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    Right - that is the 430 motor and I bought one a while back from a different source.
  10. SeattleM5
    928
    Ettore Palazzo
    Understood, thanks for the clarification Dave.
  11. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,340
    Montreal
    Tony
    very interesting site.. too bad they don't have any actuator options..
  12. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    I've been emailing with them:
    "One addition to my previous mail: I am not 100% sure if our solenoids are the same as in the 355. The Ferrari 355 has a completely different F1 system than used in all other Ferrari models.
    Before buying, please provide me photos or the printed model numbers of your solenoid valves."
    So, not yet sure if these will work on a 355.
  13. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    Looking at the photos Steve posted and what's on there website, at a minimum, the spools look different as does the orientation of the electrical connector..
  14. SeattleM5
    928
    Ettore Palazzo
    Uh oh, sorry for sending you on a wild goose chase Dave.
  15. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    Ettore - this is all good and a good find :) We just need to investigate a bit more ;)
  16. Steve355F1
    Aug 26, 2011
    9,052
    Steve
    Yes unfortunately I’ve now heard back and they are not correct for the 355F1.
    The hunt continues. Thanks anyway!
  17. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,340
    Montreal
    Tony
    well F355 is listed in the compatibility list for the part.. so it should not be there then..
  18. Steve355F1
    Aug 26, 2011
    9,052
    Steve
    Correct.
    Seems to be a common problem with parts websites and It is frustrating how often this happens.
  19. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    It may be frustrating but you need to understand that these individual components are typically not sold separately so we have some folks trying to offer solutions and in doing so it takes time to learn what parts will work with various systems.
  20. WATSON
    WATSON F1 World Champ
    Rossa Subscribed Owner
    Sep 9, 2010
    11,410
    WI
    There was a thread on this site about a year or so ago about a guy (in Seattle?) that was going through this.
    He had one solenoid where the shaft actually snapped.
    I can't find it right now, but I know he went down this path already and the details are here somewhere.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,200
    Indio Ca/ Alberta
    Grant
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,200
    Indio Ca/ Alberta
    Grant
    Also the end of that shaft would need too be turned down
  23. Steve355F1
    Aug 26, 2011
    9,052
    Steve
    The email I got back from them was clear - it won’t work on the 355.
    I didn’t ask why.
  24. Qavion
    Qavion F1 Rookie
    Feb 20, 2015
    3,132
    Ian Riddell
    Thinking aloud... It seems to be just an electromagnetically operated spring-loaded plunger. Is there some kind of threaded collar keeping the components in place?
    So...
    Coil burnt out? Probably not fixable.
    Spring broken?
    Electrical plug pins need re-soldering?
    Numbers on the old valve (transferred from the Australian Spotters Forum):
  25. Dave rocks
    15,969
    Orchard Park, NY
    Dave Lelonek
    The failure is most certainly the coil / electrical. I would think that could be fixed / retrofitted..
