Can anyone recommend a spring compressor that will work with 360 shocks. The ones I have all catch the thread on the shock body so can’t be used. Thanks......M
You probably should note whether you want it to compress the spring while the shock is mounted or removed.
95 and 99mm on the rear but that kind on clamp won’t clear the perches. Either Terry, ideally mounted but realistically I’ll have to take them off. Not a big job though.... Sent from my iPhone using Tapatalk
Do you have a photo of the shocks/springs? The tool uses both spring perch to compress the spring and then remove the lower perch lock ring. Not sure what your setup looks like.
