360 Correct Idle speed | FerrariChat
Discussion in 'Technical Q&A' started by 360CS, Nov 2, 2003.
  1. 360CS
    360CS F1 Rookie
    Nov 1, 2003
    2,641
    Kent
    Joe J
    Can someone tell me the correct idle speed for the 360, just got car back and its at 1100rpm :confused:
    Dont remember it being that high, except when cold its about 1300rpm :confused:
    Many thanks
    Joe :cool:
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Sorry to state the obvious, but this should be in your OM.
  4. Hubert888
    Hubert888 F1 Veteran
    5,441
    Manhattan & LA
    Hubert
    I believe my idle speed for the 360 is around 1000rpm. I'll check next time I take it out for a spin.
  5. thomas_b
    thomas_b Formula Junior
    Sep 15, 2003
    765
    1000rpm +-40
    throttle goes through a calibration at start-up - don't push during check
    if you are desperate you might switch off the battery master switch and go through the re-learning - not sure if that does help but the car goes through some self-learning cycle - idle calibration might be one of it
  6. 360CS
    360CS F1 Rookie
    Nov 1, 2003
    2,641
    Kent
    Joe J
    Cheers Guys got the correct idle rate now, :)
