360 F1 Pump problems and solutions | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by LMPDesigner, Jul 26, 2006.
  1. Shumdit
    Shumdit Formula Junior
    May 9, 2006
    335
    Greenville, SC
    Matthew B.
    To revive this thread: Why would you not put a 50 Amp Circuit Breaker in line as mentioned and just carry a spare 30 Amp relay with you in the car so if it ever tripped, you would just replace the 30 AMP relay then and there and then reset the Circuit Breaker?? Minimal downtime and no need for a tow to home or a dealer?
  2. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Because usually by the time the fuse has blown, the damage has been done. The relay sticks, the motor burns out then the fuse blows. Sucks really, but that's how it is.
  3. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    (1). Find a motor with more torque (adaptor mounting plate needed), so it will draw less AMP which will prevent the relay to overheat and weld together
    (2). Change to a relay that can handle more AMPs. (Looks like this is what Ferrari decided to do)
  4. traknut
    traknut Karting
    Mar 30, 2006
    121
    I am interested. I have a 2001 360 with 28,000 miles on it.
  5. coxyboy
    coxyboy Rookie
    Apr 24, 2009
    3
    Just read your explanation of how the F1 pump works,yesterday i came home switched the Engine off but something kept running i now think its the F1 pump youve been talking about,the inside cover of the grey relay is burned and ive ordered a new one but will the motor be ok or will it have been burnt out?Two questions will the new relay be damaged if i fit it with a damaged motor and where is the motor ,sorry three questions have you made a modified kit yet? Nigel
  6. psorella
    psorella Formula 3
    Oct 22, 2007
    1,249
    Canada
    Lino
    Wish I had read this sooner. I have a an 04 360 coupe with 24000 km's and my brother has an 02 spider. We would both be interested in a kit to solve the f1 pump issues. Knock on wood, have not had any problems yet in three years of ownership...
    LS
  7. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    there isn't a kit. If you use the search facility you will find many, many threads on this subject. Honest truth? Change the relay, fit the newer type pump and forget about it.
  8. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Kevin, sorry but this is factually incorrect however the party(Ferrari) line is that you can only change the whole module which includes the hydrauliuc module which is perfectly ok and the electric motor which is not! when I repaired mine I had all the cost horror stories until I started thinking about it logically i.e. there was no way Ferrari would design and build just the complete unit there just had to be this part powering something else and in the 355 F1 case I am led to beieve that the motor is in an Alfa but do not know for sure, anyway see the link for how I repaired it at a considerably less price than $15K its an easy read and the fix was just as easy and took about an hour.
    Dave
    http://www.ferrarichat.com/forum/showthread.php?t=141089
  9. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    I drive an 03 spider and would like in on a kit to mitigate the relay / pump motor failure. Just ordered a relay from Ricambi as a preventative measure.
  10. coxyboy
    coxyboy Rookie
    Apr 24, 2009
    3
    Hi i wrote about a couple of months ago when i had trouble with my F1 pump,as we all know it needs a 50 amp relay which i ordered but on trying to fit it onto the standard 30 amp socket the pins were too big!!But when i looked closely only the two larger pins wouldnt go in so i took them to my workshop and filed them down a little tricky but no big deal untill they fitted then the relay fitted and everything worked fine now with a 50 amp relay.But alass yesterday the pump motor finally gave up i think it had been damaged when the first 30 amp relay siezed up,I am now going to buy a new motor cost here is around £600 pounds but when i fit it it will be working with a 50 amp relay Nigel
  11. jgelovani
    jgelovani Karting
    79
    Would you please review my thread advise me what to do next:
    "360 F1 Hydraulic Pump Relay Pictures (inside)"
    Thank you in advance.
  12. Apache
    Apache Rookie
    Aug 18, 2021
    18
    Konzolice Richardson
    Yesterday (8/23) I was driving and after 10 miles I got a Red Blinking warning light. I have found a burnt A30 F1 Pump fuse. I replaced it with my tool kit A30 Spare. The Red Blinking light went away, and I was able to shift into gear. After idling for 5 minutes - the Red Blinking light returned.
    After reading more here - I am confident that it has to be the F1 Pump Relay. I need the Part Number to order the correct replacement.
    If anyone can provide a part number or a link - greatly appreicate it in advance.
  13. tazandjan
    39,392
    You do not want the stock Ferrari 30 amp relay, which will burn out again. You can replace it with a Tyco V23134-B57-366, which is BMW part number 61.36-8 366 646. I have had one in mine for a decade with no problems.
  14. Qavion
    Qavion F1 World Champ
    14,638
    Ian Riddell
    https://www.ferrarichat.com/forum/posts/140254670/
    I don't understand how a relay can cause a fuse to blow. Usually a faulty relay presents a high resistance which means local heating at the relay and less current at the fuse.
    It may be the pump motor.
    Apache likes this.
  15. Apache
    Apache Rookie
    Aug 18, 2021
    18
    So you're saying the the problem may not be the Relay?
  16. Apache
    Apache Rookie
    Aug 18, 2021
    18
    So I'm driving Friday afternoon, on the way to meet my GF for happy hour and suddenly my Red Warning Light started flashing. When I came to a stop, the Auto shifted to Neutral. After researching here, I learned that it could be a fuse problem. I inspected the F1 Pump fuse and found it blown (attached).
    I replaced it with the only one A30 in my Emergency Kit. It started, the Red Warning Light was gone. I put in gear, drove about 10 feet, stopped to move the other car out the way... get back in and the Red Warning Light is flashing again... and I have no more A30 Fuses.
    After reading more here, I am inclined to belive that it may be the F1 Pump Relay.
    Reading Reply #39 - I am not sure of anything right now except the fuse is the problem.
    Any help - confirmation, directions will be greatly appreciated!!
  17. tazandjan
    39,392
    Whoops, that should be X266, not X366. Typo.
  18. Qavion
    14,638
    Ian Riddell
    Generally relays fail in one of two ways....
    1) contacts fuse together making the pump run continuously. Is your pump doing this?
    2) coil goes open circuit causing the pump not to work. Is your pump doing this?
    However, as there is probably a diode across the coil in this heavy duty relay, the diode may short out. If the fuse also supplies the coil (and diode), then it's possible the fuse might blow. Let me check the diagrams....
    Apache likes this.
  19. Qavion
    14,638
    Ian Riddell
    The coil is not directly powered by the fuse but by the TCU. The TCU is supplied by the smaller yellow fuse and key power.
    The pump is known to draw a lot of current, more so as it gets older. That's why companies like Scud-Ing Swiss create relays which help manage the current.
    Try the relay. Stranger things have happened which cannot be explained by known logic.
    f355spider likes this.
  20. RayJohns
    RayJohns F1 Veteran
    7,953
    West Coast
    Ray
    The Fuse is not the problem, the fuse is the insurance. Find what is causing the fuse to blow out. In normal operation of any electrical circuit, the fuse should never fail or burn out except to protect the circuit.
    Some where there is a problem and your fuse is the last line of defense against something else either catching on fire or failing in a much more drastic / expensive way.
    Ray
  21. Apache
    Apache Rookie
    Aug 18, 2021
    18
    When the RELAY fails - does it cause the 30 Amp fuse to burn out? I have the RED Flashing Warning Light. Will not shift out of Neutral.
    I replaced the 30 Amp fuse, lights all clear, shifts into gear - after about 10 minutes the RED Flashing Warning Light returns.
    What is the correct 1-2-3 Fix and Repair Steps???
    Thanks.
    "Stranded 360"
  22. Apache
    Apache Rookie
    Aug 18, 2021
    18
    No. Mine is not continuously running. It is not running at all. I have the RED Flashing Warning Light. I checked the F1 A30 fuse behind the Driver Seat and found the burned out fuse. I replace it with the spare. The RED light cleared, shifted to gear. After about 10 minutes - the RED light returned, A30 fuse burned out again.
  23. Qavion
    14,638
    Ian Riddell
    It does sounds like a faulty motor.
    I suppose I should ask "Does the pump run continously before the fuse blows (causing the pump not to run at all)"
    Depending on the type of motor, pumps draw maximum current at start up. It's normal for the pump to cycle on and off (to stop the pump overheating and to maintain pressure). If the motor is good, the fuse shouldn't blow if the pump is running continuously or stopping and starting.
    I'm not sure what to suggest next. If it happened again and you immediately replaced the fuse and jumpered the relay (for a few seconds), the pump may work, but it may simply be because the pump has had time to cool down. It wouldn't prove that the relay was faulty.
    I'm not going to recommend jumping the relay for a long time. If the motor is faulty, it's putting stress on the wiring, fuse and motor. I wouldn't want you to start a fire.
    I suppose you could buy a current tester which you can plug into fuse sockets to monitor current. Some have a function which remembers peak current. You can fit the pump fuse to the tester to protect the wiring.
  24. Apache
    Apache Rookie
    Aug 18, 2021
    18
    Thanks to everyone that shared their experience - absolutely valuable information. Ferrari Chat is the BEST.
    I was able to resolve my RED Flashing F1 Warning Light trouble. Gearshift engage display stuck in "N"eutral.
    Solution:
    1. Replace the F1 System Pump Relay. Upgrade from the X203 to the X152. (BMW ABS Relay Part Number 6136-1-393-40 (Tyco V23134-B57-X152): $35.00
    2. Replace the F1 System Pump A30 Maxi Fuse: NAPA: $5.00
    RED Flashing F1 Warning Light gone. Gearshift normal. Trouble solved.
    I did notice that the F1 Pump Motor seem to run more quiet and quicker.
    Thanks to my fellow 360 Tifosi's ~
  25. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    6,125
    Its been a decade since i owned the 360
    I recall that my F1 pump system failed and was replaced
    I also did the fuse upgrade
    The actual pump can be rebuilt or re-sourced
    The same exact part was being made by another company for a fraction of the price
    Im sure that now with aftermarket sales you can find a good price
