360 F1 won't shift into neutral | FerrariChat
Discussion in '360/430' started by DocE, Dec 27, 2010.
  1. DocE
    DocE Karting
    Jul 27, 2009
    159
    Edmond, OK
    Name
    So I didn't put the battery tender on like a bad boy and the battery was almost down to the point that the F1 pump didn't start with the door opening but the lights came on with the key. I turned the battery disconnect, removed the connections and the terminals and charged the battery. Reconnected the terminals and turned the disconnect. The alarm beeped and the F1 pump ran as typical. I went to start the car and it is in 1st gear and will not switch to neutral to start the car. I tried holding both the paddles - it beeps and say 1st gear with auto under it. Still won't go into N. even tried the disconnect button again. To no avail. Any suggestions? Thanks!
  2. DocE
    DocE Karting
    Jul 27, 2009
    159
    Edmond, OK
    Name
    also the F1 light never came on. I pulled the relay but wasn't sure how to check to see if it's good. I then tried to restart and no pump but clicks from the right hand fuse compartment (relay maybe) so the battery has discharged again. Maybe the battery is bad and not supplying the proper voltage to allow the shift to neutral. Just grasping at straws.
  3. sk8rpatty
    sk8rpatty Formula Junior
    Dec 13, 2010
    316
    So Cal
    Patty H.
    Before restarting, did you put the key in posn II and leave it for 10 seconds as the manual suggests? This gives all systems time to come back on-line. I had to go through this step twice to clear the transmission fail fault I had after letting the battery get too low.
  4. tech4ferrari
    tech4ferrari Karting
    Jan 22, 2010
    234
    Mt Airy N,C
    casey johnson
    only way i have ever been able to get them back into neutral is with sd2 in diagnosis select neutral engagement then complete self learn...probably another way but never tried doing it any other way.
  5. DocE
    DocE Karting
    Jul 27, 2009
    159
    Edmond, OK
    Name
    So I installed a new battery just to be certain that wasn't the issue. After switching the battery disconnect switch back to on, the F1 pump started again. The car remained in 1st and wouldn't shift into neutral. I pulled back on both panels for 15 seconds and still nothing. tried clicking the paddles a few more times both and eventually it swithced into Neutral. Truly not sure what sequence worked but either way it shifted into N and the car started... Thanks all.
  6. sk8rpatty
    Dec 13, 2010
    316
    So Cal
    Patty H.
    So glad your problem cleared too. I think we both learned a valuable lesson about letting the battery get low, it just wrecks havoc with these cars.
  7. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    I'm also glad to hear that the problem was resolved by a new battery.
    Cheers.
  8. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    My former 360 had the same problem after having it in a shop for a bumper respray. I was told to pull both paddles back for about 15 seconds release and repeat. It worked perfectly. Glad you got it sorted out. :)
  9. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    I am having the same problem with my 2000 360. Can you please explain what sd2 is?
  10. Qavion
    Qavion F1 World Champ
    11,567
    Ian Riddell
    It's a Ferrari-supplied diagnostic tool that dealer workshops often have. Some independent Ferrari specialist workshops and Ferrari owners have them, but they are extremely expensive.
  11. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,701
    Melbourne Florida
    KGC
    What year is your car?
    Always wonder if certain year cars experience some problems that later get sorted out. I have a 2003 and the battery has run flat a few times and the car would not start. But with that said I never had any issues once the battery was completely disconnected from the car and recharged/reinstalled.
  12. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    #12 RedApple, Oct 25, 2021
    My year of my car is 2000. I disconnected the battery, charged it and reinstalled it. I put the key in and turned it to the 2nd setting and waited 10 seconds. Then I held both paddles towards me for 15 seconds. I did this multiple times and it's still stuck in 1st gear. I did notice that below the "1" I could see it read "AUTO". After pulling both paddles, I would get 4 chirps. Not sure what that means? I can't have the car towed because it's stuck in 1st gear. Any suggestions?
  13. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    Here a short video of me trying to start my 2000 360. Notice after the 4th beep the AUTO light comes on under the gear gauge.
  14. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    Thank you for replying to my post. Do you have any suggestions on what I should try next?
  15. Qavion
    11,567
    Ian Riddell
    Sorry, I'm probably the least-qualified person to respond to questions on the F1 system :oops: (unless the questions are about how the components are wired up).
  16. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    Got it. No worries.
  17. Qavion
    11,567
    Ian Riddell
    The Workshop Manual does mention 4 beeps, but only in relation to the installation and setup of the F1 TCU (Transmission Control Unit).
    There is also this paragraph regarding startup...
    Does the F1 car allow startup in 1st gear with your foot on the brake?
  18. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    Thank you Qavion, I did have my foot on the brake. I read an earlier post to check the engine lid is close, gas cap panel and front hood are all secure. Will try that in the morning.
    Qavion likes this.
  19. Qavion
    11,567
    Ian Riddell
    I can't find a link between the gas cap and the F1 system. I'm not sure if this is an old wives' tale :D
    Looking at the wiring diagrams for the F1, I can see links to the:
    1) Driver's door - Does the pump prime when you open the door? Opening the door will also knock the gearbox into neutral under certain circumstances.
    2) Park brake - Brake switch failures ... or simple switch stickiness... are common). Make sure your brake lights are working. You may want to lubricate the plunger on the switch above the brake pedal. I'm not sure of all the things that the brake pedal does to F1 operation.
    I haven't yet found a link between the engine lid and the F1 system in the wiring diagrams. The engine lid switch does talk to the instrument displays, the immobiliser ECU and the spider roof ECU (where applicable). Perhaps the data is sent on CAN data bus wiring from the instrument panel?
  20. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    Four chirps could mean your alarm module has failed. I had that a couple years ago, replaced the alarm module and now no longer get the chirps. I suspect the chirping is unrelated to the F1.
  21. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    #21 RedApple, Oct 25, 2021
    Thank you so much Qavion and EastMemphis for your help. I was able to get the 360 out of 1st gear this morning. There is a post that Zingara 20GTL posted back on Jun 21, 2002. By following this procedure I was able to get the car started. The car did idled kind of rough for about 15 seconds. I loaded a screen shot for reference.
    @ EastMemphis, There is an issue with the alarm that I knew about before buying the car. It was noted in a past service record.
    Now that I have the running, it's going to the shop for some maintenance work and to fix the alarm.
    Thank you every for your comments. I'm new to Ferrari community and have loved these cars since birth.
    Qavion likes this.
  22. Qavion
    11,567
    Ian Riddell
    This is a perpetuating myth. When you push the brake pedal, the pedal moves away from the microswitch which sends the "pushed" signal to the F1 TCU (see item #11).
    You only need to move the pedal a short distance away from the switch to activate it. Pushing harder will not do anything. If you clean, lubricate and exercise the switch, it should work properly.
    Anyway, glad you had some success.
    EastMemphis likes this.
  23. RedApple
    RedApple Rookie
    Jun 27, 2021
    17
    Good to know. That is so weird that it did start this morning. I'm scheduling to have car looked at.
    Thanks again for your response.
  24. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,064
    Wash DC area
    Robert
    Try pushing the brake pedal as hard as you can to the floor.
    I had a problem getting N after parking in 1st gear on a hill, years ago and an Fchatter bailed me out with that tip.
    RedApple likes this.
  25. Qavion
    11,567
    Ian Riddell
    #25 Qavion, Oct 25, 2021
