360 Front End Problems | FerrariChat
Discussion in '360/430' started by 355Aloha, Jul 17, 2009.
  1. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    360 sway bar mount comes lose after 3-5 miles regardless how tight I make it. It come lose and makes a big racket. Need Help
  2. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    front or rear sway bar? what comes loose, bushing, drop link at bottom or top?
  3. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    You should only start this kind of thread in one place. If you don't get an answer you can post and reference the other thread but posting twice is poor form.
  4. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,885
    If you are not a professional mechanic, perhaps this should be fixed by a professional?
    I think this is more involved than oil change/ filters.
  5. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    It is the front sway bar, the screws that hold the bracket to the car frame seeme to be the issue.
  6. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    Agree with prior posts that it'd probably be a good idea to take it to a dealer for inspection and repair. Locktite will keep the bolts from working loose, but that shouldn't be happening in the first place. I'd get it checked asap.
  7. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    I removed the sway bar and found one of the metal washers that hold the rubber bushing in place had a bad factory weld and had slipped almost a inch and was allowing the sway bar two move back an fourth side to side banging against the mount and making it come lose.
    Problem fixed
