360 hot starting issue | FerrariChat
Discussion in '360/430' started by mrpcar, Jan 14, 2008.
  1. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I searched and couldn't find any useful information regarding this issue.
    Typically when the car is cold it takes about 3-4 seconds of cranking to start the engine. Still longere than any other car I have owned.
    After all warmed up, if I shut engine off and start it again within 5-10 minutes, it still starts still within 3-4 seconds of cranking.
    But if I let the car sit for about 30-60 minutes after it is all warmed up it takes about 6-8 seconds of cranking for the engine to start.
    Sometimes, it will crank for so long and not start that I have to stop turn the key off and start again. Then it will start within 1/2 second of cranking.
    Have anyone else experienced this symptom? What's causing this hard to start problem? Can't imagine it to be vapor lock in a new model car like this.
    TIA
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,857
    San Jose, California
    I have not experienced this issue, but myself and many others experience a similar problem where, if you start the car up when cold, it will idle extremely rough for a few seconds. However, if, after starting it, you shut the key off right when you realize it's starting to run rough, and restart, it will fire up instantly and idle perfectly. A very knowledgable mechanic has theorized through trial and error that cars with newer batteries suffer a lot less from this problem. If it were me, I would first buy a brand new battery. If that didn't do anything, I would reset the computer.
  3. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    then again
    well, maybe not
  4. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Is that suppose to be some sort of sick joke?
  5. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I do not have the rough idle problem people have mentioned here, if anything it would be rough for couple seconds and then the engine idles perfect.
    I was thinking today if I should take the hot wire air flow meter out and use the MAF spray cleaner to clean it.
    I assume when you referring to resetting the computer is to turn the master switch in the truck off and back on?
  6. Financialman
    Financialman Formula 3
    Sep 8, 2005
    1,841
    San Jose CA
    Dan Carpenter
    My 99 starts cold after 1 or 2 seconds, hot even faster. Something must be wrong.
  7. SANguru
    SANguru Formula 3
    Jul 15, 2005
    1,258
    Bay Area, CA
    Josh
    I would check your battery as a first step.
