360 mirror question | FerrariChat
360 mirror question
Discussion in '360/430' started by Gary(SF), Mar 27, 2004.
  1. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    I admit I'm too lazy to check the manual...what is the little doohickie that sticks down from the driver's side outside mirror?
    Gary
  3. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Oh yea,same here. Me 355 has it to,i try pressing it but nowt happens, the little B****RD.
  4. Stackhouse
    Stackhouse F1 Rookie
    Feb 14, 2004
    4,691
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    That "doohickie" or "pimple" is a temperature sensor. Make sure you don't pop it!
    Out
  5. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Temp sensor for what?
  6. Stackhouse
    Feb 14, 2004
    4,691
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    Sensing temperature of course. Silly rabbit. ;)
  8. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Silly rabit here and I say again for what? Air con? Heater? Ambeant air? Heated mirror? For what?I could lick me finger and test the temp outside, is there a working reason with in the car?
  9. Stackhouse
    Feb 14, 2004
    4,691
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    Don't know if there are any other reasons for having it other than the obvious display of external temp for AC controls, that is if the car in question has automatic temp control. The traditional finger in the air works for me also, as long as its not the middle index.
