Buy
360 Problems
Discussion in '360/430' started by GS Lee, May 23, 2004.
  1. GS Lee
    GS Lee Rookie
    Apr 11, 2004
    31
    Dallas, Texas
    Greg Lee
    Seriously thinking of purchasing an 02 360 Coupe, stock except for tubi exhaust. I presently own a a 95 355 with only 6,000 miles and have had numerous small quality issues but nothing major. Can anyone advise me on problems that are common to the 360 and fixes for those problems?
    Thanks for the help,
    GS Lee
  3. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,273
    Switzerland (NW)
    I'd recommend http://ferrarichat.com/forum/showthread.php?t=6155
    The only addtl things I learned meanwhile are:
    - 360 F1s: abnormal clutch wear
    - 360 manuals: clutch pedal failure
    1995 355 with 6000 miles ? That's not much for a 9 year old car, almost qualifies as a garage queen.
  4. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    It is a garage Queen,my 355 is 1999 and has 16674.
  5. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,273
    Switzerland (NW)
    Mine is 06/98 and has 38'000km, but I guess that's not the point. I should have worded my previous post differently.
    The nature of issues you are going to run into is likely to differ a lot if you average 500 miles a year or a more 'normal' 5000 (or more).
  6. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,481
    Leawood KS/ South FL
    Thomas
    I misfired while starting her last wk....tried it again before the "Check OK" light came on and triggered the CEL...so far, she refuses to turn off. I guess this is quiet common w/ 360....It's very annoying
  8. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,330
    SF, Bay Area
    You should restrain yourself from starting her up before the Check OK light turns on. The car goes through a self-calibration and needs to see certain inputs before starting up. I've never had that problem with mine for the last three years. The only time my CEL has come on was when I smog checked it, and the tech did not tightly close the gas cap!
    I can't say for sure but the '02s are probably problem free! The 99s, 00's and early 01's had a few corks that have been fixed in the newer models.
  9. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,481
    Thomas
    Thanks.
    I will trade mine in for a 03 tomorrow...LOL.
    So...how did you reset the CEL?
    BTW, love the profile picture.
  10. racerdj
    racerdj F1 Veteran
    Silver Subscribed Owner
    Jan 19, 2003
    6,941
    Indianapolis
    DJS
    I have a 01 6 speed 5.3k miles and the onlu two issues have been a faulty gas guage (would only read 3/4 max) and a clutch slave bearing seal leaking.
  11. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    i had two 2002 360 modenas. both of them constantly had the CEL on. the dealer likes to plug the car into the computer to check to make sure there is no serious problem that caused the CEL to come on. then they turn the CEL off. however, approximately 50 percent of the 2002 360s had a software problem in the ECUs which caused the CEL to come on for no good reason. ferrari ultimately decided to replace the ECUs with 2003 ECUs which had updated software that resolved the CEL problem. if you have a persistent problem with the CEL on then the dealer has to document that the problem is not caused by loose gas cap, bad grounding, etc. once they do this ferrari will authorize them to replace the ECUs with updated ECUs.
    btw, i *think* you can reset the CEL by switching the battery off and turning it back on. you should contact ferrari and tell them your situation and ask them if it's okay to reset the CEL by switching the battery off/on. they'd probably prefer to check the diagnostics to make sure the CEL was nto set for by a more serious problem. let me know how this all works out :)
