The airbag light is ON if the battery it has little power. In order to extinguish it, is necessary connect to (SD-x or OBD-x) to erase the error of the memory. In the 355 can be reset manually to extinguish that light, (without SD-x or OBD-x). Somebody knows if also it is possible in the 360?. Alfredo.
It could be that you need to replace your battery and that might be why you are getting weird messages!
The battery already is new, but the light of airbag follows ignited. To erase the error, is necessary connect to the SD-2 in the official service. I believe that also it is possible, as the 355 (see the picture), connecting the ECU terminal to ground, But I am not sure. Alfredo. Image Unavailable, Please Login
I have 2, one Ferrari 360 Spider F1 and one Ferrari GTSTurbo. I am not sure if the 355 and the 360 are equal to extinguish the light of airbag. For that reason I ask. I do not want fuse nothing Alfredo.
Hi, I got problem for my 2004 360 Modena. The airbag light on. When I drive the car the airbag is normal, not on. One day I drive to smog check, the light show on my dash on. I tried to disconnect the electric power. It still on. Is it how to reset the light. Thanks
Resetting the battery does nothing for the airbag system. It is necessary to use the computer, SD or Leo.
Supposedly the foxwell system with ferrari software (fancy OBD) can do it. I bought one and was unable to reset mine. Not sure if there is a disconnected/defective component or problem on CAN, or it just doesn’t really reset the airbag. I wonder Has anyone else tried this system? Sent from my iPhone using FerrariChat
Dang I thought it was me. I think I’ll send them a message. I’ll let u know. Sent from my iPhone using FerrariChat
Yes I would love to have that capability as my light is on after some idiot turned the power on with the gauge cluster disconnected. Nearest computer is 1.5 hrs away.
Hey RN, I have the nt510 for Ferrari purchased like 15 months ago. What system do u have? I sent off an initial email question to tech support. Sent from my iPhone using FerrariChat
You are trying to compare Motronic 2.7 software with a system two generations later, Motronic 7.3. What works for 2.7 will not generally work for 7.3. About the only thing they have in common are the DOT mandated emissions related codes they generate. It takes an SD2 or equivalent software to turn off an airbag light on Motronic 7.3 and 7.1.1 systems.
I’m sure you are correct, but the unit was advertised as being able to communicate with and reset 360 air bag system. Sent from my iPhone using FerrariChat
I have a 2004 360 Spider with the airbag light on and my Foxwell NT530 will not communicate with the airbag module. Has any body had success with the Foxwell products on an airbag fault?
2004 F360 spider with airbag light on.... tried with NT530 Foxwell but no communications on request for codes. Works on ECU, Capote, but not gearbox or clutch. Can anybody help or does the Foxwell 5 NT530 just not work
I had an airbag issue with my 2000 360 Modena F1. I used a cheap OBDII reader that I got from WalMart just to read the codes, there was an erase all button and once I done that the airbag light is now off and has stayed off for several weeks now. I think it was only $49 and seems to have worked for me.
Necro bump. Anyone else been able to do this? I have three OBD-II dongles and four apps. None of them give options to correct air bag warnings.
