360 silencer replacement options | FerrariChat
Discussion in '360/430' started by LP360, Feb 15, 2019.
  1. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    Hello, Common issue from what I've read pretty much everywhere is that my 360 modena exhaust is making the dreaded white powder issue. I'm struggling to find a place to repair it as I really like the sound of the stock exhaust rather than replace it with a brand new one. Because I know I may have the same issue in a few years. So my question is I want to replace just the silencer. Any idea of what silencers I can use with stock entire exhaust? Many thanks.
    Sent from my CLT-L09 using FerrariChat.com mobile app
  2. Ghostdiver
    Ghostdiver Formula 3
    1,326
    Southeast Texas
    Wally Hollar
    Think you are going to be limited due the design of the system, since the cat outlets connect directly to the muffler. Most of the aftermarket systems and the factory CS system connect to the cat outlets. If you like the OEM system, you might be able to have someone weld a bead around the edges where the heatshield is just spot welded to the box. However, since the OEM heat shield is split, you are only solving half the problem as mine was leaking powder along that seam as well. I now have the CS system on my car and as long as I keep my foot out of it, it's pretty tame sounding. If you know someone good at welding, they may be able to take the heat shield off and remove the insulation which is the source of the white dust. But to do this, you have to remove the exhaust and if you are going to that much trouble, you might as well replace it.
    LP360 likes this.
  3. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    I would like a CS option, is the CS silencer direct bolt on to the original cats and the car? Can I use my original outlet pipes or do I have to buy CS pipes as well? Can I just buy the CS silencer and all is good to go on my car? Apologies for the many questions just want to double check :) Many thanks
  4. timwu12
    timwu12 Formula Junior
    919
    TX
    No, it's completely different. Aldous has a good article on his site that shows you the difference as well as a way to modify a F430's exhaust to fit the 360 and give you the same CS sound
  5. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    LP360 likes this.
  6. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    Brilliant, sounds like a easy-ish DIY job? Any hints or tips? I know a couple of people who can weld so this wouldn't be a problem. Once the silencer is off the car is it just a matter of grinding the tig weld points off and peeling the outer skin away from the exhaust to get to the heat insulation? Many thanks
  7. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
    Actually, the CS exhaust or the optional racing exhaust for the 360 is a direct bolt on replacement for the standard system. Problem is finding either of those in good condition for a reasonable price...saw a used one for 3k that came off a car that must have melted to the ground in a fire...
    The 430 uses the an almost identical muffler assy. and as mentioned, you can modify 430 tailpipes to fit a 360. You cannot use the standard 360 tailpipes with a CS/430 box as the cat outlets attach to the tailpipes rather than the muffler inlets as they do on the standard 360
  8. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
    Tried to modify my post but the clock got me. Just to clarify, the CS/430 silencer is a direct bolt in for the original 360 silencer. It will bolt up directly to the cats or test pipes, whichever you have. The tailpipes, on the other hand, are a different animal. You either have to get the correct pipes from a CS or the Racing Exhaust package, or modify 430 pipes as mentioned. I was lucky and managed to obtain the entire kit still in the wooden crate. The Racing Exhaust package is getting harder to find at a reasonable price so modifying a 430 system is the most economical way to get the "CS" sound.
    The standard 360 pipes will not work and cannot be made to work (never say never...but) with a CS box due to the attachment location of the pipes.
  9. brookliner7
    brookliner7 Formula Junior
    May 5, 2018
    780
    San Antonio, TX
    Hans
    I'd say a few things to consider, Joe from fabspeed said the 430 Muffler is indeed not the same thing as the Challenge stradale.
    "A couple of things to consider.
    Yes the Ferrari oem challenge straddle muffler and the oem 430 muffler have the exact external size and shape. Therefore the mufflers are interchangeable. However Ferrari has different part numbers for these mufflers and Xray inspection shows the internal designs are quite different and the sound was different ......the 430 muffler is more restrictive internally and attenuates controls the sound more versus the straddle coupes muffler."
    Modifying the tailpipes is for the 430 system is no easy feat as getting them to line up out the bumper just right is easy to screw up.
    Challenge stradale systems pretty much NEVER come up for sale, ask me how i know for the past year.
    The factory 360 performance system is valved and made by tubi, sounds great/better than the original coffin sized boat anchor on the back of our cars. It can be found at Ferrari dealers around the country, just make some phone calls.
    LP360 likes this.
  10. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    #10 LP360, Feb 17, 2019
    I like the look of the 430 exhaust mod, but having a quick look i find a few different part numbers? Also would the 430 exhaust cause any performance issues or CEL's?
    Many thanks
  11. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    You need a thin cutting disc and first remove the band that covers each end, then each end cover has 6 welds you need to cut off. The secret is to remove as little metal as possible to leave some for reassembly.
    You then need to unfold the seam that runs along each side and remove the covers. There may be a few tacks on these pieces on the underside but on mine they had all split. If not grind them off.
    I cut 13mm Morgan Superwool to shape and held it in place with spray mount contact adhesive (it burns off on first start) and assembly is the reverse. TIG weld the same points and tack on the straps which are purely cosmetic.
  12. nsx_2k
    nsx_2k Rookie
    Apr 7, 2009
    36
    LP360,
    The 430 exhaust does NOT cause any ill performance issues. It is louder and in some communities this is an issue. The 430 exhaust also does NOT cause any CEL's because it is a modification AFTER the last O2 sensor.
    In case anyone wants to try modifying an OEM 360 muffler/silencer. I have some lying around that I'm willing to part with for cheap, though you would have to cover shipping which is a bit pricey due to the weight of the units. PM me if you are interested
    LP360 likes this.
  13. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    Mike01606 PM sent.
  14. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    Thats great to know and will definitely consider this in the near future if all else fails.
    Many thanks
  15. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    Other than for concours originality, why do people not swap out the defective OEM silencers? They weigh a ton.
  16. nsx_2k
    nsx_2k Rookie
    Apr 7, 2009
    36
    Need4Spd,
    I believe that some people still prefer the original silencer/muffler due to personal preference of sound, cost or due to local regulations/rules limiting the noise that a car can emit. The latter is oddly a grim reality for some.
  17. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
    Thought about this before I started mod's on my car....take the original box, open it up and gut it, put in a x-pipe with a y valve similar to the CS system but inside the box. Weld it back up, wrap it in the stainless shield and have a factory appearing system, with a slightly more aggressive exhaust note!
    I'm 360 Canuck and tifosi101 like this.
  18. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    All good reasons.
  19. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    I prefer the original silencer for sound, its not deafening nor really quiet. It's right in the sweet spot for me and still sounds fantastic when i blip the throttle or under load. The CS exhaust from youtube videos is brilliant and I will be looking into getting one or the 430 exhaust in the future but for now the original is best for me at this current time.
    550nitis likes this.
  20. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    Weld up a custom exhaust using Magnaflow mufflers, stainless tubing, and tips of your choice.
    I prefer Miller welders.
  21. CCRider66
    CCRider66 Formula Junior
    454
    Sussex, WI
    Brian
    Does it really have to be Tig welded? I have SS wire for my Mig. Wouldn't that work?
    I do have a Tig, I just can't figure out how to teach my self it. :(
  22. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    I had mine done at a welding specialist but I'm sure someone will comment and let you know if you can do or not.
    I can't weld so cannot help :(
  23. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    It’s welding thin stainless sheet metal so for me TIG is the proper solution.
    MIG may work but I suspect you’ll blow holes in it, although that is speaking for myself as a fully signed up pigeon **** welder
    LP360 likes this.
  24. PrecisionMike
    PrecisionMike Rookie
    Jan 21, 2016
    16
    Northern Hemisphere
    Hi. A great Job. Where did you purchase the superwool. I've seen superwool on amazon but no reference to Morgan. I want to make sure I use the correct stuff. Thank you.
  25. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I just bought it from eBay....the 13mm or 1/2” thickness.
    M
