360 Steering Column Unknown Wire Harness Connector | FerrariChat
Discussion in '360/430' started by bhobson, Feb 27, 2023.
  1. bhobson
    bhobson Rookie
    Feb 28, 2022
    48
    Memphis TN
    Blake Hobson
    All:
    I am reinstalling my 360 dash and I came across this 4 pin connector that I don't remember being connected to anything. I don't want to get too far back into assembly and suddenly discover an "oh sh*t" moment. Any tips are appreciated. I have a manual so for all i know this is a connector to the non existent shifter paddles in an F1.
  2. Qavion
    Qavion F1 World Champ
    14,247
    Ian Riddell
    What are the wire colours?
    The paddle shift wire colours are grey/green, black/white, brown/green and blue/white
    cavlino and bhobson like this.
  3. bhobson
    bhobson Rookie
    Feb 28, 2022
    48
    Memphis TN
    Blake Hobson
    @Qavion: Yes! They are those 4 colors. Mystery solved. F-Chat is an amazing community. Thank you for sharing your knowledge.
    cavlino and Qavion like this.
  4. imahorse
    imahorse F1 Rookie
    4,310
    WI
    Dustin
    Most wiring across 360s is the same, regardless of how the cars were specced. I was told by challenge mechanics that even those cars have a lot of excessive wiring.
  5. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,943
    Melbourne Florida
    KGC
    It's not uncommon for all makes and models of cars to have only one wiring harness using only the connections that are relevant for that particular model. I've seen this many, many times. In my older cars I will find the connections for power seats, lumbar supports, etc. under the carpet in cars that do not have power seats as an option. Just something to keep in mind when re-connections are made. I usually mark my connectors with tape and numbers upon disassembly.
  6. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    Tape that plug up and hide it. Do not let it touch anything.
  7. Qavion
    14,247
    Ian Riddell
    It may not be a hazard. It depends on the car and what has been done to it.
    @bhobson Has your car been converted to a gated manual? If so, do you know if the F1 TCU is still fitted?
    Here is the wiring harness for the F1 car (only)
    On the genuine gated car, the wiring from that unused connector on the steering column only goes as far as plug 1P/6D (marked in red), forward of the centre console. The rest of the wiring shouldn't exist aft of plug 1P.
    bhobson likes this.
  8. ItalGerBrit
    Mar 15, 2016
    906
    S La
    The hazard is that it might touch something and screw up the trans and start behaving like a flippy paddle.
  9. bhobson
    bhobson Rookie
    Feb 28, 2022
    48
    Memphis TN
    Blake Hobson
    I believe my car to be an original manual (not converted). The harness in the steering column ends and 1P and there is none of the other harness shown. I was confused as i was putting on the steering column cover and had this unused connector and didn't want to complete assembly while forgetting something. Thanks to you I know it is intended to be a no-connect. Thanks again!
    Qavion likes this.
