360 Top not latching. | FerrariChat
Discussion in 'Technical Q&A' started by Richard A Bowen, Nov 6, 2018.
  1. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Works great until the point where "crab claws" grab the roller pins in windshield frame.
  2. ncipps
    ncipps Karting
    Jan 24, 2005
    97
    Sounds like you have a hydraulic problem. More than likely a cylinder
  3. vrsurgeon
    vrsurgeon F1 World Champ
    15,918
    Charleston, SC
    Curt
    As above, sounds like the seals in the cylinders are worn with resultant imperfect motion and issues. I'll bet the other cylinders also have issues, you reach a point when all need to be rebuilt/or refurb cylinders installed.
  4. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Thanks. Already have an appointment next spring for service. The top has done this only a few times all summer. Oh well, cost of ownership.
  5. mello
    mello F1 Veteran
    5,043
    CA Bay Area
    Steve
    It happened to me once. I found out that the hydraulic fluid was never changed even though it looks clean. I flushed and re-bled the system and it worked fine ever since. A two hours job.
  6. Richard A Bowen
    Nov 6, 2018
    11
    Reno, NV
    RICHARD BOWEN
    Thank you. I had all the fluids flushed in May, but I'm confident they didn't do the hyd fluid that operates the top. Getting ready to put the car "up" for the winter, so will attack it next spring.
