Does anyone have a 360 with standard Tubi? I have just had one fitted, absolutely fantastic, but I have the small orange engine warning light appearing on the dash, after covering about 250 stunning miles throught the black mountains. I rang the dealer and he said this sometimes happens as they bypass the emission filter when fitting the Tubi. It's going in on Tuesday for a diagnostic. Has anybody had the same or similar warning light/problem associated with Tubi fitment? Much appreciated Rob
Rob, Thats the ecu warning light... prob find that the thermo sensor is faulty or has not been connected or tampered with.... If you had test pipes, these are removed and refitted in the process. If you only had exhaust changed they will of needed to modify the old valve sensors/ vacum tubes could be this too ...its more than likely a simple remedy. Out of interest who fitted the pipes?? Joe
Thanks for the info. Dick Lovett in Cardiff, first Tubi they have fitted. I'm taking it in tomorrow. Let's hope it's only a simple re-map.
