360 Won't start? | FerrariChat
360 Won't start?
Discussion in '360/430' started by bgmix, Mar 12, 2010.
  1. bgmix
    bgmix Formula Junior
    Aug 1, 2009
    612
    AZ|NYC|FL
    Bob Giammarco
    My 360 that usually starts right up won't start.
    It's on a tender. Tender says battery is good. Lots of clicking, but no cranking. Drove it Monday to multiple destinations without issue. Anyone have advice to offer?
  2. Bones2U
    Bones2U Formula Junior
    Jul 13, 2008
    814
    Ontario
    Just because it is on a Battery Tender that doesn't mean that the battery is in good shape. I would suggest that if you get the clicking sound yet the engine isn't turning over that you still are not getting enough juice from the battery to run all the computers....etc. Try hooking up jumper cables to the battery directly and remove the tender. I had a battery Tender fry a battery of mine once. Never used one again after that.
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,447
    how old is your battery?have the battery checked out first
  4. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    +1 on the battery, it can cause many headaches. Definitely start there.
    'D
  5. bgmix
    Aug 1, 2009
    612
    AZ|NYC|FL
    Bob Giammarco
    Yes, I'm beginning to suspect the battery is bad regardless of what the tender says. Thanks!
  6. bgmix
    Aug 1, 2009
    612
    AZ|NYC|FL
    Bob Giammarco
    #6 bgmix, Mar 12, 2010
  7. jjsaustin
    jjsaustin Formula Junior
    May 11, 2008
    579
    Austin, TX
    Jim
    I thought I read here that jumper cables were a bad thing and could damage the electronics, or am I mistaken??
  8. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,857
    San Jose, California
    I heard that too. For what you have in your car, I'd just buy a new battery and try it.
  9. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    Pull her out mate and have her checked out. :):)
    It sounds like it may have dropped a cell. :):)
    Yep, jumping a 360 can cause a voltage spike which can harm some electrical components. :):)
    I think the speedo is bad for playing up after a jump start. :D:D
  10. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    So true!!! Do not jump your car ever!!! I learn that at the hard way.
    Just take your voltimeter and check the battery at 20V DC setting. Your battery should be reading between 12.2V and 12.4V with the engine off. Or just take that battery out and go to AutoZone to check it and re-charge it.
  11. bgmix
    Aug 1, 2009
    612
    AZ|NYC|FL
    Bob Giammarco
    Bad Battery. New one installed. Want to consider the whole sealed/gel battery thing, but for now a good old Die Hard did the trick. Their "international 48" fits perfectly, has the vent and is still lighter than the original. Thanks for everyone's input!
  12. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    To bad you already bought a new battery. I would recomed the Odyssey 925. It works great and you save around 13 pounds over stock.
  13. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    My 360 had the same issue and it was on the Ferrari battery charger that came with the car.
    I would not do anything fancy on your f car. The dealer did the parellel batttery thing in my car and still could not get it to start. I few minutes later he repleced the battery and life was good again.
    good luck to you.
    lee
  14. PAP 348
    Dec 10, 2005
    100,216
    Pap
    Good to hear Bob. :):)
  15. bgmix
    Aug 1, 2009
    612
    AZ|NYC|FL
    Bob Giammarco
    I know. The Odyssey 925 needs some mod to get it in properly and I'm taking the car on a drive tomorrow with the local club. I didn't have time to deal with a project, I wanted the problem solved. I'm still considering the Odyssey.
  16. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    I think it's closer to 20 lbs. I posted the difference on a thread a while back. Great battery. No need for a tender.
    Ray
  17. romaryj
    romaryj Rookie
    Feb 1, 2010
    8
    My 2003 360 (30K) will not start, was fine last week. This week the CHECK OK light goes on and then ASR light replaces it. Next to speedometer the BRAKE and ABS lights are lite. On the multidisplay, the engine symbol and AIR BAG lights stay lite. I get nothing when trying to start. Battery or something my serious??? None of these lights were on last week.
  18. romaryj
    romaryj Rookie
    Feb 1, 2010
    8
    ..just a low battery charge.....all's well for now....
