4 point seat belts | FerrariChat
4 point seat belts
Discussion in 'Technical Q&A' started by Steve King, Dec 11, 2003.
  1. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Has anyone mounted a 4 point seat belt set up in a 308. If so how did you do it and where did you get the belts. Did you mount a sub-frame behind the seats . Also do you have any pic's?
  2. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    the lap belts can mount to the same points where regular belts mount and top belts can be mounted up high on shelf behind your head,
    for the one near the door I welded a ring onto a tab and put it under the existing belt connection--hides away nicely when not in use. will post a pic later
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I bought a four/five belt set up from Peter Sweeney. Involves removal of the original belts and putting a bar between the upper mounting posts. I ran that way until installing race seats when I added the sub belt.
    A similar set up could be fab'd using some angle iron and a cross bar with threaded ends.
    HTH
