430 Turn Signal Relay | FerrariChat
Discussion in 'Technical Q&A' started by Ray Smith, Jul 20, 2020.
  1. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Can anyone tell me what I need to remove in order to access the turn signal relay? I'm doing a reconnaissance in preparation for installing Stef's full light package. His directions have a photo but I'm clueless as to where
    "...the original Turn Signal Flasher is located at the passenger side behind the glove box, mounted on the passenger side wall."
    The photo indicates that wherever it is, there is a body color painted surface behind it.
    Thanks,
    Ray
  2. ditpixs
    ditpixs Karting
    Apr 22, 2019
    231
    Nor Cal - Tracy
    Aaron
    Good choice with Stef's products. I have his flasher controller and F1 relay eMT.
    If you look under the dash to the right of the battery cover, more on the right side wall (think behind the door hinges) there is a control box mounted vertically. You will leave the box where it is, but just remove the big connector from it. If you don't find it I can go take a video.
  3. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Thanks, I'll go look. I just bought his 430 Rear LED solution kit and it includes the Turn Signal Flasher relay replacement.
    Thanks again.
    Ray
  4. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
  5. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    I think the relay is to the right of this one. I'll crawl under there again to make sure.
  6. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Yep, it's the one with the white plug on the right. Thanks much for the pointer!
    Ray
    ditpixs and Qavion like this.
  7. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    I bought the Smart F1 Relay (basic) as well. Eventually, I'll get the DRL kit.
    Ray
    ditpixs likes this.
