456 fuel injection / electrical problem | FerrariChat
Discussion in 'Technical Q&A' started by Gordo456GTA, Feb 28, 2004.
  1. Gordo456GTA
    Gordo456GTA Rookie
    Jan 14, 2004
    3
    I have a 1997 456 GTA with a recuring injection/electrical problem in which one of the injector banks shuts off randomly. Anyone have this problem or any recomendations?
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,526
    Commifornia
    The Bad Guy
    I would suggest taking a look at the wire connections for the fuel timing. They should be located at the rear of one of the intake cams. If they get loose it will mess up it fuel supply and fuel timing. The other thing is are you getting any engine lights?
  3. joelk
    joelk Rookie
    Nov 1, 2003
    35
    Perhaps try resetting the ECU. I had similar problem on mine (engine intakes were pulling in too much air on one side) - but resetting it did the trick.
  4. Gordo456GTA
    Gordo456GTA Rookie
    Jan 14, 2004
    3
    No engine lights, only perfomance problem.
    Thanks!
  5. Gordo456GTA
    Gordo456GTA Rookie
    Jan 14, 2004
    3
    Sounds like a good idea , will do it tomorrow!
    Thanks.
  6. Onlinesys
    Onlinesys Formula Junior
    May 1, 2002
    425
    Hong Kong
    Excuse my ignorance Gorda456GTA. Could you please advice the performance problem encountered? Loss of power?
    Rgds
