456 GT DIAGNOSE | FerrariChat
456 GT DIAGNOSE
Discussion in 'Technical Q&A' started by Sugesh C, Nov 28, 2020.
  1. Sugesh C
    Sugesh C Rookie
    Nov 28, 2020
    3
    Sugesh Chemarathil
    NEED HELP- I have Ferrari GT 456 Model 1995- Where is the Diagnose socket location for this model
  2. Qavion
    Qavion F1 World Champ
    11,566
    Ian Riddell
    It may not have one (well, not one that you would be familiar with)
    I assume you have a Motronics 2.7 engine management system. On the 465, there is a test plug near each ECU for a Ferrari SD-1 diagnostic scanner.
    On some Ferraris with the 2.7 system (e.g. the F348 and early F355's), there was a pushbutton fitted to the ECU harness which you could press in a certain way and you would get the check engine light to flash, giving a diagnostic code. Some cars weren't fitted with a button, so you had to install one yourself. I recall there is a procedure in the F355 workshop manual on how to use this pushbutton.
    Anyway, look around for a two-wire harness with two wires on it coming from the ECU or a pushbutton near the ECU
    Sugesh C likes this.
  3. tazandjan
    38,085
    Robin- Affirmative, OBDII was not installed on the 456 GT and GTA until MY 97 in the US. No MY 96 456s.
  4. Qavion
    11,566
    Ian Riddell
    Is it a USA car or Euro car? To which country was car first exported (from Italy)?
  5. Sugesh C
    Sugesh C Rookie
    Nov 28, 2020
    3
    Sugesh Chemarathil
    Italy
  6. Sugesh C
    Sugesh C Rookie
    Nov 28, 2020
    3
    Sugesh Chemarathil
    Its from Italy
  7. wmuno
    wmuno Formula Junior
    434
    Wilmette, Illinois
    Bill Muno
    All cars sold in the US after 1/1/96 have OBD-II. The socket is located under the dash to the left of the steering wheel. If your car is from Italy, it might not have the socket.
  8. Qavion
    11,566
    Ian Riddell
    If your car was first owned/driven in Europe, it won't have an OBD2 socket. If it only has a 3 pin diagnostic port (plug), you will have to take it to a Ferrari specialist. If you can find the ECUs, see if there are any two pin plugs attached to the ECUs.
  9. tazandjan
    38,085
    Bill- Yup, but his is a 95 Euro model.
  10. Island Guy
    Island Guy Karting
    Feb 20, 2020
    125
    Island Guy
    Regardless of the market, all ECUs have the ALDL connectors. Find a garage with an SD1 or SD2 with porting software. Simple, easy...
  11. Qavion
    11,566
    Ian Riddell
    Tell that to the Ferrari owner who lived on an island in the English Channel and had to take a hazardous ferry ride to this nearest Ferrari tech :D
    We're still not sure where Mr Sugesh Chemarathil is located.
  12. Island Guy
    Island Guy Karting
    Feb 20, 2020
    125
    Island Guy
  13. Island Guy
    Island Guy Karting
    Feb 20, 2020
    125
    Island Guy
    Sorry, I thought the goal was to get the car diagnosed and repaired....
  14. Qavion
    11,566
    Ian Riddell
    It is the goal.
    So you're saying there are no simple workarounds for do-it-yourselfers on 456 2.7's?
    There is a momentary switch attached to the ECU on some 456's, which may have diagnostic functions:
    https://www.ferrarichat.com/forum/posts/147364844/
    Other Ferraris have the wiring for the switch, but no switch. Adding one (or shorting out these wires for a specific time period) may be simpler for some folks.
  15. Qavion
    11,566
    Ian Riddell
  16. Mecauto SA
    Mecauto SA Rookie
    Feb 10, 2022
    1
    Mecauto SA
  17. Qavion
    11,566
    Ian Riddell
    #17 Qavion, Feb 10, 2022
    Since you have a real overheat problem.... either your right hand cat is disintegrating (internally) or you have too much fuel going into your engine on the right hand bank.
    Inspect the rear of the RH catalytic converter.
    To much fuel = leaky fuel injectors, air leak after the MAF, faulty MAF, faulty O2 sensor, etc, on the right hand bank.
    Note that the 456 has a crossflow engine, so the applicable MAF and associated air intake will be on the left hand side of the car.
    What year is your car and where are you located? Do you know if your car has a Motronics 2.7 or 5.2? No one on the forum seems to know if the 456 has a diagnostic switch for the Motronic 2.7 ECU. Ferrari dealers may have a proper Ferrari SD tool for diagnosing the 2.7.
    Were your RH exhaust pipes also glowing?
