458/488 Brake Recall | Page 14 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    The brake fluid cap is such a PITA to take off because the plastic surrounding it is so high up.
  2. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    640
    Austin, TX
    Got the letter the other day and it all makes some sense to me now.. If the brake fluid and air above it in the reservoir heat up and expand, the cap is supposed to allow the excess pressure out, but if it doesn't, then the pressure could force some fluid past the seals into the booster.
    r6elmo, elt360 and Sargepug like this.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    This suggests that overfilling the reservoir could be a problem.
  4. PMiranda
    Jul 23, 2004
    640
    Austin, TX
    Indeed overfilling would hurt
  5. hgoodwiniii
    hgoodwiniii Formula Junior Silver Subscribed
    Apr 24, 2015
    280
    I received my letter today; Whoooo!
    Sargepug likes this.
  6. Sargepug
    Sargepug Formula Junior
    Mar 23, 2020
    888
    NYC
    Really? I had no issues at all....
  7. PMiranda
    Jul 23, 2004
    640
    Austin, TX
    Fingers crossed that part availability is WAY better than the great airbag recall. I think that took 5 years to get all the cars.
  8. BigJay2050
    BigJay2050 F1 Veteran Rossa Subscribed
    May 27, 2014
    7,191
    With the current supply chain issues, it may take way longer than 5 years to get to all the cars.
  9. rw99
    rw99 Karting
    Jan 1, 2019
    130
    SF Bay Area
    Rich
    So are we to infer that Pista, F8 etc. have a different reservoir and/or cap? And that’s why they’re immune? Or that it’s the combination of our “old” cap and MC/boosters that creates the issue?
    I feel a bit skeptical of any solution that just happens to be the simplest and least expensive.
  10. rockminster
    rockminster Formula Junior Silver Subscribed
    Nov 20, 2003
    874
    Lake Tahoe
    So for those of us with a hard pedal that Ferrari has said is normal, will they replace the brake booster?
  11. jdlegg
    jdlegg Formula Junior
    Dec 22, 2009
    252
    Bryan / San Rafael
    James D
    Got my letter today as well. :-(
  12. ilko
    ilko Karting
    Aug 20, 2008
    155
    The letter states that Ferrari will reimburse you if you've already had to do the repair. I plan to send them my parts receipt, since I did the work on my own and see what they say... o_O
    mdrums likes this.
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Yeah. I still haven’t received the latest letter.
  14. Scout123
    Scout123 Formula Junior
    Nov 1, 2017
    575
    Nothing in our letter from Ferrari states not to drive the car until the replacement part arrives and software update are completed. I plan to continue driving my 13 458 spider keeping in mind using e brake if a failure does occur.
    430jm likes this.
  15. up4speed
    up4speed F1 Rookie Silver Subscribed
    Feb 16, 2012
    3,700
    Long Island, NY
    Chris
    I found the same thing.
    My work around was to take off the plastic cover to the right of the brake reservoir (the one covering the A/C line fittings) , then stick my fingers in there, and under the tank and push up, while unscrewing cap with the other hand. When you push up on the tank, it is much easier to get torque on the cap, and easier to actually grab the cap.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Good question. There may be a number of different problems and causes.
    I once had an M3 that ran ok in most driving but seemed short by 100 HP when pushed. It went back to the dealer several times. They checked plugs, ignition, all sorts of things.
    I figured out that the likely cause was an underperforming fuel pump. They refused to change it because there were no codes indicating a failure. I told them to do it anyway, and that if it’s not the problem, I’d pay for it (car was under warranty). They did. And it was. So I got it free.
    You with a hard pedal know that your problem isn’t a bad reservoir cap. It’s either a bad booster or bad check valve or line that deprives the booster of the vacuum needed for power assist. It’s also possible it’s debris in the line like one of the posters above. But changing the cap isn’t going to fix lack of boost.
    Since it’s a safety issue not a “convenience” issue like my M3 pump, I’d do what it takes to fix it, and argue with Ferrari later about who should pay. Lack of good stopping ability is not normal.
    Don’t buy the bs that these are racing brakes that only stop well when hot. I run OEM pads and rotors. They have always had good initial bite, even when cold, and with only moderate pedal pressure. The key is not to let a car wash or detailer use spray-on silicone tire dressing that might contaminate the rotors.
    Those whose brakes are functioning normally, yeah, wait for the new cap. Maybe there’s really nothing wrong with your car anyway.
    FerrariCognoscenti and rw99 like this.
  17. Sargepug
    Mar 23, 2020
    888
    NYC
    It might behoove us all, to open the cap before each drive, to let out and previously built up pressure...
  18. ilko
    ilko Karting
    Aug 20, 2008
    155
    Every time you open the reservoir you introduce humidity into the system which is the worst thing you can do to brake fluid.
    Viperjoe likes this.
  19. Sargepug
    Mar 23, 2020
    888
    NYC
    Maybe on a DD capacity it can truly be detrimental, but most of us I assume, drive the car sparingly...
  20. ilko
    ilko Karting
    Aug 20, 2008
    155
    Do you also brake sparingly from triple digits before entering a corner? :confused:
  21. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,928
    France
    They will argue that what they would pay for is only the cheap plastic cap since according to them, it's where the problem is :D
    So far I've been lucky with my car (braking from 166 mph less than 500 ft before a corner on track), I hope it will go on that way.
    In France (and I suppose it's the same elsewhere in Europe) there is still no news of the recall (for the Takata airbags, the news also arrived long after in the US, which seems to be more sensitive specially when there is a risk of legal action).
    430jm likes this.
  22. 430jm
    430jm Formula Junior
    Jun 11, 2017
    451
    Atlanta
    And folks here often lament our legal system…
  23. Sargepug
    Mar 23, 2020
    888
    NYC
    I didn't say I brake sparingly, I use the car sparingly, so cap won't be opened a number of times like a DD. And I don't track the car.
    IMO, I think releasing pressure in my situation by removing the cap, if not every time / now and then, is better than a potential brake failure.
  24. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,482
    Tampa FL
    2019 488GTB here and got my letter today.
  25. up4speed
    Feb 16, 2012
    3,700
    Long Island, NY
    Chris
    A little off topic, but do you know how we can clean contaminants, like silicone spray, off of the rotors? I would like to get maximum efficiency, just in case a prior owner along the way contaminated them.
