458 challenge help | FerrariChat
  1. Farbod Farmand
    Nov 20, 2020
    17
    southern California
    Purchasing a 2014 458 challenge evo, doing some of the basic maintenance myself, the seller doesn't have any of the spare parts... it'll be used for track days only...
    1. Air jack system; where do I get the air lance (Sobek?)? Nitrogen system: any nitrogen tank set up will do? is there a specific regulator? refill at welding shop? max/min PSI? the procedure of lifting that car? any safety info?
    2. what pump (JEGS pump) and setup/process for pumping OUT fuel?
    3. where do I get the PREMIER dry neck filler - for easier fuel fill?
    4. where can I get the center lock wheel socket?
    Appreciate any input
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,823
    The Cold North
    Tom
    Seems you have bought a bit of a bugger. If I was in your position, a trip to a dealer who has a race team should be in order to sort this stuff out. It may be the most cost effective at this point.
    windsock likes this.
