News
458 rough idle when cold
Discussion in '458 Italia/488/F8' started by Brad Lano, Jul 14, 2019.
  1. Brad Lano
    Brad Lano Rookie
    9
    Brad
    Hello to All.
    I just bought a 2012 458 Italia with 8200 miles. Lots of carbon. I have a few questions. I drove the car for about 50 miles last night. Today when I started the car it had a loping in the idle for about 30 seconds and then it smoothed out. I am thinking that is old fuel but not sure. This is my first Ferrari and am not familiar with the engine characteristics. Any help would be grateful. Red with Tan interior.
  2. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Silver Subscribed Owner
    Jul 3, 2006
    25,889
    Aspen CO 81611
    FelipeNotMassa
    I have a 2012 Spider with 30k+ miles. No problems. Maybe you need new fuel injectors. Get some Techron to help clean your injectors. If that doesn’t work you may have to replace yours. Best
  3. veilstylez
    veilstylez Formula Junior
    256
    SoCal
    I get this too...like a small loop/shake and rougher idle when the car is warming up at cold start. But as soon as the revs come down its smoother.
  4. DefunctNeurons
    DefunctNeurons Karting
    May 15, 2018
    244
    Atlanta, GA
    Trevor
    I had this (as do most) on my F430, but it’s not an issue. Normal for that car. My 458 doesn’t do this. I concur with @PhilNotHill, run some injector cleaner and a tank of Shell through it, exercise it and get it hot. Run up the rev range. Depending on how the previous owners drove it, it might just need an Italian tune-up. Won’t hurt to try before looking at more expensive options.
  5. DefunctNeurons
    May 15, 2018
    244
    Atlanta, GA
    Trevor
    I forgot to say congrats on the car! I just traded up for mine a few weeks ago as well!
  6. Eilig
    Eilig Formula 3
    2,297
    Cavallo
    My 2010 Italia does same.
  7. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,684
    My 2011 Italia does the same, but not every time
    alibo70 likes this.
  8. Brad Lano
    Brad Lano Rookie
    9
    Brad
    Thanks for your input. I believe it sat to long. I will try some injector cleaner and see if that helps. I'll stretch her legs this weekend and give you an update.
  9. Eilig
    Eilig Formula 3
    2,297
    Cavallo
    Mine often sits 3+ months without running and I've wondered if that could cause/contribute to this.
  10. jjp11
    jjp11 Karting
    Sep 1, 2013
    68
    mine does the same thing.. i have a couple other non-Ferrari cars that do basically the same thing as well. normal.
  11. Brad Lano
    Brad Lano Rookie
    9
    Brad
    I just started using non oxygenated premium fuel. I can get that in Arizona it is a lot more stable and no alcohol. Does anybody use higher octane than 91?
  12. Eilig
    Eilig Formula 3
    2,297
    Cavallo
    I use 93 octane with no ethanol and it still idles rough at start up.
  13. alibo70
    alibo70 Rookie
    Dec 11, 2018
    7
    Ali
    My 2011 does the same. Just thought it was a characteristic of the car.
  14. hmfic1
    hmfic1 Karting
    164
    Scottsdale
    Jerry
    2013 Spider, will idle a bit rough until the choke kicks off, think you will find most cars will, even a Ferrari, Just drive it and have fun.
    Like all cars, they have funny sounds now and then. Not a big deal.
  15. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Moderator
    Mar 18, 2014
    3,107
    Europe, but not by much.
    Nuno
    My 2011 when cold runs rich, but I wouldn't exactly call it "rough".
    I'd recommend to check the simplest things first: fill the tank with fresh fuel. If it doesn't work, I'd check spark plugs and injectors.
    Kind regards,
    Nuno.
  16. kn1ghtley
    kn1ghtley Karting
    Nov 30, 2013
    87
    Southern California
    Brent
    Mine does the same, normal
  17. Brad Lano
    Brad Lano Rookie
    9
    Brad
    I put in fresh fuel and drove it hard for about 85 miles. Noe it runs great. When i start it cold all i hear is the injectors and a very smooth engine.
    Thanks for all your input
  18. PhilNotHill
    Jul 3, 2006
    25,889
    Aspen CO 81611
    FelipeNotMassa
    Glad our suggestions worked.
    Now you need to disconnect the lines to the muffler baffles so you can hear that gorgeous motor music all throughout the rev range. :)
    Wazmo and AlfistaPortoghese like this.
