488 GTB 7500 rpm Rev Limiter | Page 12 | FerrariChat
Discussion in '458 Italia/488/F8' started by cpiguy, Aug 15, 2015.
  1. ForeverCar
    ForeverCar Formula Junior
    Jan 20, 2017
    307
    8000 rpm
  2. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,879
    France
  3. Horst997tt
    Horst997tt Karting
    Jun 4, 2017
    107
    #278 Horst997tt, Oct 4, 2017
    Yes, my 2017 488 GTB is like in the video, 7800 rppm reading of scale ist OBD 2 real 7750 U/min
    and absolutely limit in LC mode (and with part throttle, which makes no sense).
    In auto mode/manual mode lower see video, 7500 -7600 rpm.
    So I am little bit disappointed, My ( future) 720 S makes 8500 rpm like quoted from
    Mclaren, optimal gear switch 8200 U/min independend from auto// LC mode,
    in manual you can hit rev limiter at 8500 rpm
  4. Horst997tt
    Horst997tt Karting
    Jun 4, 2017
    107
    I think Ferrari is cheating at 488 , no owner can see 8000 rpm!
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,261
    Mel
    O.K. ! Happy owner :D
  6. ForeverCar
    Jan 20, 2017
    307
    Of course, this is minor in the grand scheme of things. It's just a bit confusing when the spec of max power output is at 8000 rpm yet you can't reach 8000 rpm.
    I bought an ODB2 logging device and will get some logs when I get a chance.
  7. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,576
    8000 was a marketing symbol, because announced 7500 real trs instead of the 9000 trs ot the previous generation wasn t possible !
  8. cpiguy
    cpiguy Formula 3
    2,137
    Westlake Village, CA
    Arnie Friedman
    As I've said many times, nothing will ever justify why Ferrari has made the decision to spoof they 488 buyers. I'm quite frankly shocked that the media didn't ripe this wide open. It's like they're paid off to keep there mouths shut. I've owner 53 cars, many of which high performance, and never owned a car that didn't rev to the advertised red line, and in almost every case slightly above. I wish there was an official answer, but I have not been able to find one.
    PS: I've always preached "under commit, over deliver"... Get it Ferrari
    AlfistaPortoghese likes this.
  9. Horst997tt
    Horst997tt Karting
    Jun 4, 2017
    107
    I have the problem that in auto mode engine is running in
    rev limiter at 7500 U/min up to 0.3 s -0.5 s before shifting but only
    at shift vom 4 th to 5 th gear, also in race mode.
    As anyone same problem?
  10. ForeverCar
    Jan 20, 2017
    307
    I still haven’t used my ODB II logger yet and I rarely use auto mode. However, in manual mode, I noticed 4th to 5th is where I find this lower rev limit troublesome. It seems it’s an even lower rev limit than 7500rpm from 4th to 5th full throttle in non-PS (that’s what’s on the US button) mode.
  11. Horst997tt
    Horst997tt Karting
    Jun 4, 2017
    107
    #286 Horst997tt, Oct 10, 2017
    Yes , rev limiter is from 4th to 5th gear 7400 rpm, in 2nd and 3rd 7650 rpm (in manual mode also),
    so rev limiter is not exactly stable,
    it is vary from gear to gear,
    So when shifting manual , I have to remind that at shift from 4th to 5th
    gear rev limiter comes earlier, that is annoying.
  12. Gh21631
    Gh21631 F1 Veteran
    9,154
    East
    Novitec software will fix this and add ~100hp. :)
  13. Horst997tt
    Horst997tt Karting
    Jun 4, 2017
    107
    Novitec is piggyback box and cannot
    change rev limits
  14. exoticcardreamer
    exoticcardreamer Formula 3
    Dec 9, 2014
    1,051
    usa
    doesitmatter
    720s seems to be different than 488.
    in 488 you hit rev limiter before it actually red lines in the display. 720s the rev limiter in the display shows that you will hit it at 7500 rpm but it allows you to go past it and shift at the points you mentioned. I was pretty confused first time on track and thought I was hitting the limiter at 7500 rpm in 720s. I had mclaren do some data logging and then tried it again. It does hit the limiter in the points mentioned in the manual.
    I told them that they may want to move the red lines to the actual limiter -:)
  15. 95spiderman
    95spiderman F1 World Champ
    17,433
    ny
    imo ferrari doesn't need to pay off media bc the media cars DO rev to 8k! That's how they get such amazing performance in the tests. Ferrari has been sending media cheater cars since forever
  16. John117
    John117 Rookie
    Sep 14, 2016
    36
    Do your research before making ignorant comments. All the media test cars and demo cars also had a rev limit of 7500rpm.
  17. Qbix
    Qbix Rookie
    Nov 2, 2015
    9
    So they (Italians) cheat with curb weigh, power, performance, acceleration and now this. No to mention about all that journalist cars tuned-up.
    I think I will skip 488. Maybe with the next gen they will set their minds right.
  18. 95spiderman
    17,433
    ny
    Im sure you're sarcastic but reality is ferrari is best regardless of cheating so why do it? Be like porsche whos cars always out perform factory claims. Ferrari should be above this by now.
  19. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,427
    Bournemouth, UK
    Most cars have the cut off farther up their red line. So what the 720 does is rather common.
  20. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,427
    Bournemouth, UK
    That's both unsubstantiated and false. People in here have measure their cars and they are in line with what the test cars achieve. Moreover, revving higher does not necessarily equate to higher performance and that's especially true for turbocharged engines.
  21. ferraribrit
    ferraribrit Karting
    Feb 27, 2009
    159
    Ridgeland, MS
    Paul
    All I can say is, for those who would skip the 488 because of 500 revs: you don’t know what you’re missing!!!!
    Best, Paul
  22. ForeverCar
    Jan 20, 2017
    307
    Definitely keeping my 488 GTB. It’s strange the 4th to 5th rev limiter is 7400 rpm and I’d like to understand more. It’s likely “this is how it is”. I’m secretly hoping there’s a better answer than that but I should know better.
  23. Horst997tt
    Horst997tt Karting
    Jun 4, 2017
    107
    me too, but problem is, rev limiter is different from gear to gear, lowest rev limits are in 4 th gear with 7400 rpm, 2 nd gear is
    7650 rpm, driving in manual mode, you have to remind rev limits of
    each gear.
  24. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    I agree. There was no need for Ferrari to choose this path. You paid top dollar for a top car that in practice and on the road, doesn't do what on paper the maker says it does.
    That is indeed puzzling. I assume that that "floating" rev limiter has to do with some technical aspect/constraint (?)
    Kind regards,
    Nuno.
  25. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    Why is this such a debated topic ? Ferrari have boost by gear. Their ECU programmers with real engine dyno's have mapped everything. Its all integrated. Gee there is no doubt in my mind that is also looks at all the other sensors and inputs them in the loop. This engine is Forced Induction, NOT Normally aspirated. What Ferrari has done is a great thing.
    Feel sorry for the 458 owners living in high altitude , they might have a higher red line but their power drastically goes down.
