488 GTB aftermarket wheel size. | FerrariChat
Discussion in '458 Italia/488/F8' started by Anindith Reddy, Apr 21, 2019.
  1. Anindith Reddy
    Apr 30, 2018
    43
    Anindith Reddy
    Hello everyone, Im trying to get the right size wheels for my 488 and havent found much info on offsets.
    Can anyone provide what size and offset aftermarket wheels they have gone with. Thanks in advance. Image Unavailable, Please Login
  2. Anindith Reddy
    Apr 30, 2018
    43
    Anindith Reddy
    Can anyone provide the size and offsets of their aftermarket wheels or what size works for the 488GTB
  3. Viperjoe
    Viperjoe F1 Rookie
  4. johnr265
    johnr265 Formula Junior
    Jul 1, 2010
    398
    Mid-Atlantic
  5. Anindith Reddy
    Apr 30, 2018
    43
    Anindith Reddy
    Hi Joe, tirerack just lists sizes that will work, and not necessarily "Flush" of perfect fitment which is what Im looking for.
  6. Anindith Reddy
    Apr 30, 2018
    43
    Anindith Reddy
    Thanks for your response.
    So as per this thread the fitment is :
    488 specs
    Front 9J X 20 ET 44.7, Rear 11J X 20 ET 38.5 mm
    special specs
    Front 9J X 20 ET 44.7 mm, Rear 11J X 20 ET 48.4 mm
    So for a flush fitment on the 488 we can go about 5 to mamybe 10 more mm from the stock specs.
    Would still be interested to see what specs people are running on their HRE ADV1 or other aftermarket wheels
  7. johnr265
    Jul 1, 2010
    398
    Mid-Atlantic
    That's correct, I believe they were 10mm spacers for the rear.
  8. Anindith Reddy
    Apr 30, 2018
    43
    Anindith Reddy
    Hi bumping this old thread to see if anyone can share pics of their aftermarket wheels and their width and offsets.
  9. mdrums
    mdrums Formula 3
    2,234
    Tampa FL
    Dang... 4 years later and you are still trying to get offset info?
    Try this :https://www.1010tires.com/Tools/Wheel-Offset-Calculator
    My 488 - I kept stock size wheels but had the offset done to fit slightly more flush. Like adding 10mm space front and 15mm spacer rear....that is all I did. David @Wheelb set the wheel specs up. I know he was wanted me to do 20/21 or 21/22 sizes but at the time I was going for a nice looking set of lightweight mono block wheels I'd use on the track - never ended up tracking the car ...LOL... however if you order some HRE or Ankry wheels from him we will set the offset up for you.
    RoadRonin and jm2 like this.
  10. 05F430F1
    05F430F1 F1 Rookie
    2,811
    Fort Lauderdale, Florida
    Todd
  11. Eric C
    Eric C F1 Veteran
    9,100
    St. Louis, MO
    Eric
    AD211 likes this.
  12. PCJR
    PCJR Formula Junior
    253
    PA
    Viperjoe likes this.
  13. Anindith Reddy
    Apr 30, 2018
    43
    Anindith Reddy
    thanks for the information guys. Im inclined to sticking to a 20/20 setup also but going an half inch wider on the front wheels and an inch wider at the back. in terms of offset im thinking a +27 in front and +38 in the back. Waiting to hear back from HRE aswell.
  14. Dicecal
    Dicecal Formula 3
    1,804
    Phoenix, AZ
    Rob
    I have a 20/21 HRE setup from Wheels Boutique with appropriate offsets to make the wheels flush with the bodywork. They have the best prices on HRE usually, I’d reach out to them to discuss the offsets they are using….it’s what they do all the time.
