488 GTB Gas Pump Issues | FerrariChat
Discussion in 'Technical Q&A' started by Advncdfinesse, Dec 23, 2021.
Tags:
  1. Advncdfinesse
    Advncdfinesse Rookie
    Dec 23, 2021
    2
    LA
    Chris Kelsey
    Hi everyone,
    I’m taking my 488 from SoCal to NorCal then back. I’m slightly concerned because I’ve had trouble pumping gas at certain gas stations.
    Basically the pump won’t recognize that it’s in the hole and just doesn’t pump any gas.
    I’ve had this issue at Chevron for certain but I don’t remember any other gas stations I’ve had the issue with.
    Does anyone have any tips on how I can make sure the gas will pump properly even at troublesome gas stations like Chevron? (Maybe it was just that specific Chevron I don’t know)
    I don’t want to get stranded in the middle of Cali because I can’t pump gas! Lol.
    Thanks a ton in advance.
  3. Dave Bertrand
    Dave Bertrand Formula Junior
    693
    Castle Rock, CO
    I really hate Cali's pump nozzles. If Shell nozzles work reliably, avoid Chevron and top off at Shell whenever you get below 1/2 tank. And bring a 5 gallon gas can (filled at all times) with you in the trunk in case of emergency. And a roadside assistance membership.
  4. stasha
    stasha Karting
    Sep 10, 2021
    106
    steve steve
    Curious. Why do you think Chevron nozzles have a problem? Are they made differently compared with other gas stations? Do they have more sensitive settings?
    I always heard that the nozzles "detect" fumes then shut off, but now that i am forced to think about it, i can't imagine that a hose gushing gas is able to detect fumes.
    If fume detection really is a thing, is it because the gas tank tube in the 488 is too long (or too short), and Chevrons detectors are too sensitive?
    I wonder if Internet is my friend.
  5. stasha
    stasha Karting
    Sep 10, 2021
    106
    steve steve
    Here it is:
    Gas pumps stop when there is no more air flowing through the nozzle and the change in air pressure causes the nozzle valve to shut automatically.
    So its likely how Chevrons air pressure sensors are set, huh.
  6. Dave Bertrand
    693
    Castle Rock, CO
    As a follow up to my previous response, maybe the simplest way is to just bring an empty 5 gal gas can with you. If you run into trouble, dispense the gas into the gas can, then transfer it to the car.
  8. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,026
    Santa Clarita, CA
    Try putting two fingers between the gas filler neck on your car and the black flex part of the gas nozzle. Keep an air opening between the two parts and the pump won’t click off all the time.
  9. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,556
    Weston, FL
    Scott
    My 360 has a similar problem. I pull the nozzle back a couple inches and pump a little slower. Seems to make it work just fine.
  10. Advncdfinesse
    Dec 23, 2021
    2
    LA
    Chris Kelsey
    Thanks for the info everyone!! I will definitely try/keep these in mind!
