488 - 488 Pista top seat belt holders rattle | FerrariChat
488 488 Pista top seat belt holders rattle
Discussion in '458 Italia/488/F8' started by lamborarri, Jul 16, 2019.
  1. lamborarri
    lamborarri Formula Junior
    Nov 15, 2015
    452
    My pista has a rattle at a lower speed which I figured it's coming from both driver and passenger's top seat belt holders (housing). I'm not 100% sure if that's the problem yet. Anyone experiences this?
  2. Gisi
    Gisi Karting
    Dec 6, 2006
    85
    SWITZERLAND
    Christopher
    the belt is pushing on the carbon seat, same here. when the passenger seat is empty, put it more in to the front, problem solved
  3. lamborarri
    Nov 15, 2015
    452
    Yes but that seems not the problem that my car has.
  4. Scudmsl
    Scudmsl Formula Junior
    837
    I don’t have that issue, but I do have a problem keeping the gas pump from shutting off during refueling, even with very little gas flow. Seems like there is an obstruction of some sort. Anyone else?
  5. RayJohns
    RayJohns F1 Veteran
    7,403
    West Coast
    Ray
    On my 458 the seat belt had these back plastic caps that were kinda loose on there and kept popping off. I'm not sure if that's the same thing you are talking about, but on my car I just took them off and tossed them in a box.
    Ray
  6. clockem
    clockem Formula 3
    May 18, 2009
    1,117
    Chicago
    Gary
    If it’s only happening on the passenger side when you have no passenger likely it’s the metal part of the seat belt hitting the carbon fiber of the seat.
    Does it happen when you have a passenger in the car that is wearing the seat belt?
  7. lamborarri
    Nov 15, 2015
    452
    It happens on both sides, not passenger related. Not related to the seat belt itself.
    I will give it a try to remove them. Hopefully that's the case.
    Not sure where you located. Some of our gas nozzles have this problem in the West Coast here. I normally just push the rubber part of the nozzle all the way and lock it in then start pumping gas. It works fine here. I think the design should be similar.
  8. Shack
    Shack F1 Rookie
    May 2, 2005
    2,509
    Earth
    For what its worth I had the same thing on my 458 a few year ago. Sound transfers and it ended up not being anything to do with the seatbelt but in fact a "spot weld" that was causing the issue in the engine bay. Dealer after many how's found the issue. Your dealer has the most experience and IMO I would get them to sort it.
    Caeruleus11 and lamborarri like this.
  9. lamborarri
    Nov 15, 2015
    452
    Thank you. If this is not a common problem I will just send it in later. Just got the car for a couple of months, still enjoying it. I don't wanna send it in yet lol.
    Shack likes this.
  10. Scudmsl
    837
    East coast here. Will give it a shot. Thx.
