488 Replacement | Page 32 | FerrariChat
488 Replacement
Discussion in '458 Italia/488/F8' started by ajr550, Feb 21, 2018.
  1. Albert-LP
    Albert-LP F1 Veteran Owner Rossa Subscribed
    Sep 1, 2010
    8,187
    around Modena, Italy
    Alberto Mantovani
    The V6 will have just one turbocharger. But it will be a very advanced model, with better performances than the actual twin turbo design
    Caeruleus11, of2worlds and arhimede like this.
  2. crinoid
    crinoid F1 World Champ Silver Subscribed
    Apr 2, 2005
    10,018
    LaCrinoid
    Oooooohhh sounds a bit racey. A bit F1 ish.
    of2worlds and red passion like this.
  3. F2003-GA
    F2003-GA F1 World Champ Rossa Subscribed
    Nov 2, 2003
    13,406
    Sunbelt
    Bro
    So it will have hybrid ? No lag ?
  4. Klamathpro
    Klamathpro Rookie
    Nov 20, 2013
    1
    This is not really true. While there are shared components within the same generation, there are many changes from the previous gen. The 570S tub and 720S cage share no similarities with the 650S/12C tub. The 720S engine is a completely different engine, 4.0 liters vs 3.8, and the turbos went from mechanical wastegate TD04's to electronic TD05's on the 720S.
    With that said, Ferrari does have a patent on an electric turbocharger. Best of both worlds. NA sound with boost. I think the 488 replacement will have that. It may require some batteries for stored energy to power them.
  5. Lukeylikey
    Lukeylikey F1 Rookie Silver Subscribed
    Mar 3, 2012
    3,699
    The 720 gets its capacity by being basically a stroked version of 650 engine. It is only a rework, same basic engine. 720 tub looks identical to a 570 tub with a roof on. This is a development of the 12C tub mainly with better sidesills. Didn’t know about the electric turbo patent. I wonder why this hasn’t been done before - seems like a real advantage?
  6. ingegnere
    ingegnere F1 Veteran Silver Subscribed
    Sep 12, 2004
    5,567
    Montreal
    It will still have the turbine on the exhaust side (just decoupled from the compressor) so exhaust will still be muffled.
    Caeruleus11, arhimede and of2worlds like this.
  7. wrs
    wrs F1 World Champ Owner Rossa Subscribed
    Jul 11, 2015
    13,924
    Lakeway, Texas
    William
    The turbo charger powered by exhaust gasses is a very efficient use of otherwise wasted energy. Making a smaller engine with more power means having a more efficient power conversion of the fuel and the fossil fuel is going to still have to be the source for the ICE part of the system. I don't see this kind of hybrid design (electric turbos) which seems less energy efficient being better other than eliminating turbo lag. A secondary electric system is required to run the electric turbos at higher voltage, again, more complexity, more points of failure. It might make sense for F1 applications but on street cars I am not so sure.
    Seems to me the Audi electric supercharger approach is just adding another layer of complexity and more points of failure in the design. Electric turbos mean more software and more room for errors there too. I don't experience turbo lag in the 488 because of the way Ferrari brings the power and torque in, it's tapered and so you don't get the big launch off the line but the benefits of efficiency and higher power are still there in the power band.
    theplanner, LVP488 and of2worlds like this.
  8. 444sp
    444sp Formula Junior
    Dec 18, 2016
    508
    wrs, fil, Lukeylikey and 2 others like this.
  9. Lukeylikey
    Mar 3, 2012
    3,699
    That’s very clever, the sort of tech Ferrari have become so good at. This idea genuinely removes turbo lag if they want it to - the intake side and exhaust side are simply not connected. It also seems to remove the wastegate because additional boost seems to be used elsewhere in the driveline.
    of2worlds likes this.
  10. F2003-GA
    Nov 2, 2003
    13,406
    Sunbelt
    Bro
    I hope they expand the options list - Would love to see electrochromic windows
    Shadowfax likes this.
  11. Caeruleus11
    Caeruleus11 F1 World Champ Rossa Subscribed
    Jun 11, 2013
    11,719
    I wonder if it will always have the turbine spinning- I wonder if they have a way to bypass this turbine- and thus give a purer sound. I doubt it could be used all the time, but if they adopt regen brakes, it might be possible.
  12. maha
    maha F1 Rookie
    Mar 17, 2014
    3,732
    dinajpur, bangladesh
    mahmud
  13. isot
    isot Formula 3
    May 6, 2012
    1,221
    Lucca
    Alberto
    This is the "mulotipo"... new components, old body...
    The car with camo is the "prototipo".. brand new car
  14. Motorwerks
    Motorwerks Formula Junior
    May 8, 2013
    265
    Bloomfield Hills
    Satish Tummala
    Ha ha...The next car will likely have none of these attributes you desire
    Doug23 likes this.
  15. cesman
    cesman Formula Junior
    Jul 13, 2008
    783
    London, UK
    Craig
    I heard recently that 488 replacement will be shown at Geneva - car been brought forward from Frankfurt 2019 reveal - deliveries to commence in Q3/4. Pista & Spider all sold out so no reason to hold back new car.
  16. Motorwerks
    May 8, 2013
    265
    Bloomfield Hills
    Satish Tummala
    That would be awesome! I plan on going to Geneva. Hopefully it's there!
  17. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,059
    France
    They decide how they distribute the production anyway, so I do not think there could have been any reason to delay or move backward a new car related to the sales of the Pista.
    Actually introducing a new car sooner than expected would more probably indicate issues with current range sales than the opposite.
    Anyway, for some time the "consensus" has been that in Geneva they'll introduce a V8 positioned higher than the 488 and that later they'll present a V6 to really replace the 488 (as far as I understood).
  18. cesman
    Jul 13, 2008
    783
    London, UK
    Craig
    This topic has been doing the rounds on this forum and I can’t really understand it. From what I am told the car being spoken about is in fact the 488 replacement. Anyway, there will be lots of speculation - we will know more in the next few months with previews slated for December - although that sounds very early to preview a launch car for Geneva (March). Time will tell.
    488 orders must certainly have gone off a cliff - lots of barely used 488s available on market. All production now allocated to Pistas - and Spider (quietly) not limited like previous versions.
  19. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,059
    France
    In this case it could be that they cannot fill the production with the far more expensive Pista and need something else to cover for the diminishing 488 sales.
  20. Doug23
    Doug23 Karting
    Jun 23, 2017
    193
    Italy
    F142M-FL could be seen as a replacement for 488...
    Inviato dal mio BAH-L09 utilizzando Tapatalk
  21. cesman
    Jul 13, 2008
    783
    London, UK
    Craig
    Doubt that - Ferrari been there before. As soon as Special Version launched the “standard” model will taper - usually quite planned and predictable. 488 not exactly a slow car so no reason for demand to fall unusually. Ferrari would have known about 720S for a while - everything quite predictable. The Ferrari product guys are superb at sensing market demand and meeting it (or as the case typically is - just not meeting it)
  22. Shack
    Shack F1 Rookie Owner Silver Subscribed
    May 2, 2005
    2,646
    Earth
    I have a wagyu burger bet with my dealer that the above is what will happen :) - My info is from FChat - no idea where he gets his info from :)
    Garretto likes this.
  23. F2003-GA
    Nov 2, 2003
    13,406
    Sunbelt
    Bro
    :D:D:D Your dealer probably getting it from the Horse's mouth
    Shack likes this.
  24. Shack
    May 2, 2005
    2,646
    Earth
    I should clarify - The above is what I think - he has a different view i.e. the 488 replacement will be in Geneva NOT the car positioned above the 488 :) - Apologies
  25. Dilusha
    Dilusha Formula Junior
    Dec 10, 2016
    769
    Well, the dealers usually get their info straight from Maranello. I'm afraid you'll lose the Wagyu burger! :p
