512TR oil leak | FerrariChat
512TR oil leak
Discussion in 'Technical Q&A' started by racedecknc, Dec 1, 2003.
  1. racedecknc
    racedecknc Karting
    Nov 24, 2003
    198
    Winston Salem
    Ed
    Is there a common place for oil to leak on a (1992) 512TR with 15k miles on it?
    We're also looking for a tool kit and a used (ha) Tubi exhaust to go with the rear window we're searching for.
    Ed
  2. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    Top three:
    1 - front engine oil line fittings
    2 - drain plugs (tank and engine)
    3 - valve cover corners
    regards, jim
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    There are two very common sources of oil leaks
    1. Engine
    2. Gearbox
    Anywhere at anytime, usually the result of sloppy maintenance/abuse ie over or under tightening of fastenings and poorly applied/incorrect sealants.
  4. Wildwarrior
    Wildwarrior Formula Junior
    Mar 26, 2003
    280
    PA
    Glen Winters
    If you had 30000 mile belt service ,you may need to check rubber cam seals if not done right they can rip and drip! Yes you need to pull motor to replace! Hope that isnt' the case.
