550 Maranello airbag ECU | FerrariChat
Discussion in '456/550/575' started by Emartleb, Feb 29, 2016.
  1. Emartleb
    Emartleb Karting
    Dec 6, 2004
    79
    San Francisco, CA
    Val Beltrame
    Good afternoon.
    I read through all the posts that were responsive to a search on this subject. It seems some had made some progress in locating new ECUs and others were working toward locating someone who could rebuild them. Then the trail went cold. My car's airbag light is now on and I'm on the hunt to reset/repair/rebuild/replace the ECU. My mechanic and the local Ferrari dealers were not able to "communicate" with the ECU with the usual diagnostic tools. Has anyone come up with a solution or am I destined to drive around with a red light on the dash?
  2. Emartleb
    Emartleb Karting
    Dec 6, 2004
    79
    San Francisco, CA
    Val Beltrame
  3. Rifledriver
    34,119
    Austin TX
    No replacements I am aware of. There are rebuilders advertising on the internet.
  4. FPFaeth
    FPFaeth Formula Junior
    Dec 3, 2009
    663
    NY
    Frank Faeth
    Question: If you change airbags, does that affect the airbag light? That is, is there any 'pairing' occurring? Thanks. Frank
  5. Estroso
    Estroso Karting
    Jun 16, 2015
    82
    Woodstock, GA USA
    Jean-Luc
    Look for a replacement airbag ecu. Either a US or EU spec part will work.
  6. henryr
    henryr Two Time F1 World Champ
    21,702
    Atlanta
    Juan Sánchez Villa-L
    hope that umbrella policy is valid...
  7. Rifledriver
    34,119
    Austin TX
    I am no lawyer but if in fact Ferrari and TRW have both told us they are not supplied now and there is no plan to supply them in the future (and they have) that would seem to put any reasonable effort on our part to maintain the operation of a primary safety system in the realm of "good faith effort" and place responsibility on the rebuilder. It isn't a perfect world and any of us can be sued at any time for anything but at some point we need to get on with life. Replacement with a new unit was considered the commercially acceptable repair method. That option is no longer available to us. There is no perfect solution to the problem as it stands. We can choose to knowingly have a nonfunctional air bag system or make a reasonable attempt to maintain it.
  8. 2HotShoes
    2HotShoes Karting
    Sep 2, 2015
    103
    Chicago, IL USA
    Tal & Beryl
    We had a persistent SRS (Safety Restraint System/seatbelt) light on our 550. We knew the SRS was fine but the code was thrown (we caused it) and because it's a factory code it's not trivial to clear. We took the car to a factory shop and they could not communicate with the airbag ECU using Ferrari's own SD2/3. This seemed peculiar but after an hour they just gave up, charged us, and sent us on our way. A couple weeks later a local independent shop with a Leonardo easily cleared the code. Turns out the factory shop had plugged in their computer incorrectly. Inexcusable.
  9. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    It doesn't look like Ricambi, our title sponsor, has one, but I know that MPI Ferrari had one... I sold it to them. NOS.
    Part No. is 164645.
    Their website is: Ferrari and Italian Sports Car Restorer
    I'd give them a call.
  10. tazandjan
    38,085
    Many of the dealerships have nobody who knows how to work on anything much earlier than an F430, especially if it requires cables other than an OBDII connector.
  11. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Excellent point, Terry.
  12. 2HotShoes
    2HotShoes Karting
    Sep 2, 2015
    103
    Chicago, IL USA
    Tal & Beryl
    To Terry's important and very useful point. When we took the 550 into the factory shop for the SRS light reset I had the opportunity to watch the tech with the SD attempt the reset. He tried to do it, as he sat in the driver's seat, by connecting the Ferrari computer to the OBDII. He then spent much of the next expensive hour fiddling with the computer after which he announced, as if it was the car's fault, that the factory computer couldn't communicate with the SRS. I learned later it's a different system and that trying to correct a 550 SRS fault through the OBDII is simply not possible; the systems don't touch and the SRS is reached via an entirely different test port on the other side of the car. When I described this scene to the fellow that later fixed the problem (easily) he laughed quietly and nodded knowingly. Thus is the grace and beauty of true expertise which is, unfortunately, a rare and beautiful thing to see.
  13. 15765
    15765 Formula Junior
    May 14, 2012
    302
    Las Vegas NV
    Chuck King
    Someone who knows their way around Washington should contact the DOT and see if we can get a factory recall to force them to supply the ECUs because of the dangers of the Airbags not working.
    Chuck
  14. Emartleb
    Emartleb Karting
    Dec 6, 2004
    79
    San Francisco, CA
    Val Beltrame
    Thanks very much, gentlemen.
    I have passed the contact info for Motion Products to my mechanic (he will contact them) as well as the non-OBDII port for clearing the code in the first place.
    Thanks again!
  15. Vereeken
    Vereeken Formula Junior
    May 16, 2014
    264
    Belgium
    The airbag diagnose port on European 550s can be found behind the glove box
    It is a tree pin connector but with only 2 wires connected
    Fairly fat yellow cable with black yellow connector and an end cap
    The same connector can be found in many FIAT products
    In your diagnose software look for anything that says Twr my 97
    Alfa 147 FIAT Punto come to mind
    I do have the impression that not all generic diagnose software is able to handle the twr codes
    Good luck
